5 members (wvstovebolt, Shade Baby, greenie-reddy, Peggy M, 1 invisible), 121 guests, and 5 robots.
Topics128,083
Posts1,055,967
Members48,430
#122813 11/03/2006 3:40 AM
I am going to update the intruments on my 64. I have not been able to find any supplier with a plain steel instrument panel. I have found one that will sell me a non-polished aluminum panel. I want to paint it the same color of the truck body. Question is, will it hold paint ok, and if so would I need to do any prep work? Thanks, Scott.
#122814 11/03/2006 2:42 PM
Anonymous
Unregistered
Anonymous
Unregistered
As I was informed, aluminum needs to be primed with epoxy primer. If you have a polished surface that might even be harder for primer or paint to adhere to.
#122815 11/03/2006 4:35 PM
ozscott,
I am not a body-man, but I have painted aluminum before. It was prepared in a conventional manner...sanded, cleaned and painted. It never came off, looked fine and was just as durable as any metal that had been painted.
This would be 'especially' true to a interior item. If I were going to paint my AlumaWeld drift boat, I would probably get a touch more technical with my coating!
Stuart
#122816 11/03/2006 7:31 PM
You could have it anodized to your choice of colors, powder coated, or painted. You just need to use an aluminum-compatible primer.
Paint & Body Shop moderator
#122817 11/03/2006 8:37 PM
I am not shure of the spelling,but when they paint aircraft they use(alodine)it's a chemical that eaches aluminum and turns it gold as if it where anodized. I's rinsed off with water and the gold looking surface is ready for paint.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#122818 11/03/2006 9:24 PM
Yes alodie is the right spelling. I did a search on yahoo every thing you need to know is there.
user
#122819 11/03/2006 10:21 PM
On aircraft we used to use the alodine, then epoxy prime and paint.
#122820 11/04/2006 1:40 AM
Duponts veri-prime is self etching and is
perfect for Your needs...its 2 part mix, 615 &
616...Zinc-cromate is the old aluminum primer, but I
don't believe that is around anymore, it was an enviromental type problem....BB
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#122821 11/05/2006 9:51 PM
I have used both veri-prime and PPG's Epoxy primer and to my supprise the epoxy primer actually bonds to aluminum better than the self etching primer. Go to your PPG dealer and ask for DPLF primer. It comes in several different colors. It is kind of pricy though.
#122822 12/06/2006 8:28 PM
Junior Member
Junior Member
yep, etch prime, in aerosol form, finish as normal
