1 members (CuzzFuzz), 83 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#1220280 06/06/2017 5:57 PM
Not exactly high performance, but does anyone make an aftermarket hood hinge for a 53 3100? Looking for something more sturdy and nicer looking than the stock ones.
Very expensive, BUT, may be worth it.
After spending DAYS trying to assemble and align a 2 ton front clip with new off the shelf hood hinges, I rebuilt the old worn out hinges by machining new pivot point rivets. Everything lined up perfectly.
Threw the new ones in the scrap.
I must have spent the equivalent $$ in time and labor.
I have used many a set of used hinges without issue with hood fitment on ADs. They weren't horribly ragged, but they did have some wear in the rivets. Poor hood fitment of ADs is almost always due to things other than the hinges.
The instructions in the Truck Shop Manual actually refers to how the spring support assembly adjustment procedure actually accounts for the slack in the hinge rivets.
Now if you want to discuss the hinges in '55.2 through '59, and '67 through '72 hood hinges, I cannot help you. I don't think those hoods are supposed to close right. frown
Carl
I don't always agree with Carl, well, very few times, but I'll agree with him on the hinge subject. AMEN Mr. Carl.
My point was that the new repro hinges were garbage.
The truck was an old farm field truck with broken cab mounts and lots of loose parts. Some of the pins on the hinges were worn almost 1/2 way through.
After rounding out the oval holes and making select fit rivets, the old hinges were better than the new ones because they had been made correctly in the first place.
Good save Jim! For some oddball reason, I actually enjoy taking on similar seemingly-ridiculous-to-others saves. It gives me a sense of accomplishment.
Well, if you agreed with me all of the time, then that would make one of us unnecessary. smile
