| | | Forums66 Topics128,093 Posts1,056,154 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 41 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 41 | Not exactly high performance, but does anyone make an aftermarket hood hinge for a 53 3100? Looking for something more sturdy and nicer looking than the stock ones. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Very expensive, BUT, may be worth it. After spending DAYS trying to assemble and align a 2 ton front clip with new off the shelf hood hinges, I rebuilt the old worn out hinges by machining new pivot point rivets. Everything lined up perfectly. Threw the new ones in the scrap. I must have spent the equivalent $$ in time and labor. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I have used many a set of used hinges without issue with hood fitment on ADs. They weren't horribly ragged, but they did have some wear in the rivets. Poor hood fitment of ADs is almost always due to things other than the hinges. The instructions in the Truck Shop Manual actually refers to how the spring support assembly adjustment procedure actually accounts for the slack in the hinge rivets. Now if you want to discuss the hinges in '55.2 through '59, and '67 through '72 hood hinges, I cannot help you. I don't think those hoods are supposed to close right.  Carl
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I don't always agree with Carl, well, very few times, but I'll agree with him on the hinge subject. AMEN Mr. Carl. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | My point was that the new repro hinges were garbage. The truck was an old farm field truck with broken cab mounts and lots of loose parts. Some of the pins on the hinges were worn almost 1/2 way through. After rounding out the oval holes and making select fit rivets, the old hinges were better than the new ones because they had been made correctly in the first place. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | My point was that the new repro hinges were garbage. The truck was an old farm field truck with broken cab mounts and lots of loose parts. Some of the pins on the hinges were worn almost 1/2 way through. After rounding out the oval holes and making select fit rivets, the old hinges were better than the new ones because they had been made correctly in the first place. Good save Jim! For some oddball reason, I actually enjoy taking on similar seemingly-ridiculous-to-others saves. It gives me a sense of accomplishment.
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I don't always agree with Carl, well, very few times, but I'll agree with him on the hinge subject. AMEN Mr. Carl. Well, if you agreed with me all of the time, then that would make one of us unnecessary.
