6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#121559 08/09/2006 12:59 AM
Hope this is the right place for this.What is a good spray in sound deadener for inside the doors on my 55 2nd? THX in advance.
#121560 08/11/2006 9:00 PM
I see nobody's responded to your question so I'll just throw out an idea. I don't have any experience with spraying on a sound deadener. I used a stick-on sound sound deadening mat on the exterior my doors (under the door panels). But, you might consider using undercoating spray. You can get it at any auto supply or Wal-Mart. Just be sure you have all the glass and mechanial hardware removed or it might be a mess to clean up.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
#121561 08/11/2006 9:16 PM
haven't done it yet but i was kicking around the idea of useing that expandafoam type insulation you get in a can to put in the bottoms of my doors. should be good for insulating against noise and temperature too.
it ain't yours till you bleed for it...
i reject your reality and substitute my own...
"morticia" a 69 c-10 (original)
97 ram
#121562 08/11/2006 9:55 PM
2 Offline
glen That expanding foam will trap water and rust the doors. Go to Home Depot and get some of the stickey back roofing. It is about 24 bucks a roll and works quite well and won't trap water.
Tom
#121563 08/11/2006 11:23 PM
Here is a couple of links to check out. I found this on the web.
http://www.sounddeadenershowdown.com/
http://www.secondskinaudio.com/cgi-bin/index.cgi
I am going to use the second skin.
Tom
48 Chevy 3100 Shortbox 5 window
"The Big Dog"
#121564 08/13/2006 3:54 AM
Agree with 235 Fat Fenders, Home Depot Peal &
Seal Roofing Material. I used it and it really
sticks and no smell. Good Luck
http://community.webshots.com/user/46metal
#121565 08/15/2006 9:44 PM
Whatever you do in the doors, make sure you keep the drains open! The water is supposed to run down the windows and out through the bottom of the doors. Clog up a drain hole, and it will rust out in short order.
Paint & Body Shop moderator
