| | | Forums66 Topics128,050 Posts1,055,684 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Hope this is the right place for this.What is a good spray in sound deadener for inside the doors on my 55 2nd? THX in advance. | | | | | Joined: Jul 2002 Posts: 59 Member | | Member Joined: Jul 2002 Posts: 59 | I see nobody's responded to your question so I'll just throw out an idea. I don't have any experience with spraying on a sound deadener. I used a stick-on sound sound deadening mat on the exterior my doors (under the door panels). But, you might consider using undercoating spray. You can get it at any auto supply or Wal-Mart. Just be sure you have all the glass and mechanial hardware removed or it might be a mess to clean up. 72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
| | | | | Joined: Apr 2005 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 20 | haven't done it yet but i was kicking around the idea of useing that expandafoam type insulation you get in a can to put in the bottoms of my doors. should be good for insulating against noise and temperature too. | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | glen That expanding foam will trap water and rust the doors. Go to Home Depot and get some of the stickey back roofing. It is about 24 bucks a roll and works quite well and won't trap water. Tom | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | Agree with 235 Fat Fenders, Home Depot Peal & Seal Roofing Material. I used it and it really sticks and no smell. Good Luck http://community.webshots.com/user/46metal | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Whatever you do in the doors, make sure you keep the drains open! The water is supposed to run down the windows and out through the bottom of the doors. Clog up a drain hole, and it will rust out in short order.
