1 members (SlimSix),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I've searched and looked all over but can't find it. Someone had put together a disc brake "kit" with caliper brackets and a list of parts to buy from a modern Chevy truck. Can anyone point me to a link for that? I remember seeing it about a year ago.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Jan 2015 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 48 | The username is Thoraco as I remember. I bought the kit and put my truck on the road today and those brakes stop you on a dime. | | | | | Joined: Jan 2015 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 48 | Chad here is the contact info you're looking for. The Hollister Road Company Dave Chapman, 713-937-0387 I had a few snags on my install and he was right on top of helping with the project. | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Thank you - did you change your master cylinder also? How about the rear brakes?
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I see they also have a rear disc kit also.
| | | | | Joined: Jan 2015 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 48 | I bought the master cylinder he suggested and also added a vacuum tank. Rear brakes are drum and are more than adequate with those huge front discs. | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Ok thank you. My drum brakes stop me good, actually too good - they drag really bad when they get hot and I cant seem to overcome it. The springs just cant overcome the hydraulic pressure.
| | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | I have a 51 GMC 1 ton heavy fire truck and bought my disc brake setup from Dave. I also bought the dual master cyl and booster which installed in the stock pedal position from another vendor. The master cyl set up clears the PTO and the disc brake brackets from Dave used 2011 Chev van 1 ton calipers and rotors.
Get the remote reservoir, Daves kit, retain the stock steering rod, new vacuum booster/master cyl and CHEV van parts and you will be very happy. I retained the rear drums and now my truck stops on a dime with ease!
Call Dave Chapman! | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 |
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Here's another kit that I've seen used on some other forums. says 55-59, but should work on the earlier trucks too. The 52-59 trucks used the same spindle and hubs. Toms Classic
| | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I bought the Hollister setup for the front. It was a lot more expensive, hope its worth it. I have not installed it yet but the quality of the brackets for the price looked rough. For the rears I bought the setup I posted earlier.
| | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Let us know how it all works out, I would be very interested. | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Well I have it all put together and trying to get the system bled and work out the bugs. If anyone does this Hollister kit, some of the parts on the part list are incorrect. Front hoses were not correct, and the instructions were decent but at times confusing.
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I would encourage anyone that is interested in Hollister's disc kit to call Dave Chapman. I'm surprised you say some of the hoses are incorrect. Dave is more than willing to help out. He even offers a Rockauto shopping cart list for all needed parts. I would call him direct vs. going through ebay.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | He was nice, I emailed him a few times. The front hose part numbers were not correct and I let him know which part numbers worked. I'm just saying don't run out and buy your parts to try to do it over a weekend like I did.
| | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | I'd be interested in the parts list. I know someone parting out a 3500 Express van. What do I need? I may go for the Hollister kit in a few months. Swapping engines right now but the opportunity to score the parts from the van would be now.
I have the parts for the DRW set up already. Should have a second axle in a few weeks with the full DRW still on it is time to get on it!
Thanks!
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | If you email Dave at Hollister he is very helpful, or you can download the instructions and parts list off his website. But I used the OEM 2003 Chevy 2500 HD front rubber lines from Napa, rather than the part numbers Dave had. They are 1/4" and he recommended 3/16". But I needed it on the road and I read a lot of articles that said there is no pressure difference between the 2 sizes. Mine works fine at 1/4" for what its worth.
