2 members (dt235sd, Otto Skorzeny), 103 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#1205168 02/21/2017 1:49 AM
Hi all
Just a quick question about where the small oil can spring loaded braket is suppose to mounted. When I removed it, it was on chassie rail on L/H side in engine bay but it looks like wrong place.
My chev is a 42 1 1/2 ton truck R/H drive built for Australia
Cheers Justin
Aus42blackout #1205302 02/22/2017 12:45 AM
Are you talking about an oil filter? I had a '40 Chevy 1 1/2 ton cab with a canister oil filter mounted on the firewall on the driver's side. JP
Aus42blackout #1205331 02/22/2017 4:03 AM
this is a little oil can used for maintenance, topping up oil in starter motor and generator it would hold approx 250 ml- or 1 cup oil.
It also has EAGLE stamped on its side
cheers Justin
Aus42blackout #1205337 02/22/2017 4:36 AM
Justin,
I have a salesman book to go with my '42 American Chevy pick up and there is no such oil can listed. That doesn't mean that it is not a correct factory item with a right hand drive export truck. I suspect, however, that your oil can is aftermarket or from some other vehicle.
I have seen oil cans on the firewall of cars from the late teens and early 1920s when there is no automatic lubrication of the rocker arms. The driver is required to stop and oil the rockers every 100 miles or so. Thus, a convenient oil can is mounted nearby.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
TGP Offline
That sounds like a Military part.
They were big with having the oil can and bracket mounted on the firewall.
Usually in the lower corner opposite the steering.(Pass. side)
Could that truck possibly be Ex military?
A lot of Dodge WC's had them.
Just a thought,
Tom
Aus42blackout #1205509 02/23/2017 1:12 PM
Justin,
Here is where the oil can bracket is located on a left hand drive 1941 Chevy.
pic
Paul
Lots more pictures
Paul_WNC #1205526 02/23/2017 4:27 PM
TGP Offline
Originally Posted by Paul_WNC
Justin,
That's where they mount it on the 40's Dodge WC.
Tom
[img]http://www.surfacezero.com/g503/data/3176/2013-11-11_17_03_39.jpg[/img]
Paul
Aus42blackout #1206252 02/28/2017 1:59 PM
thanks for the pictures of what the bracket looks like, my truck was built for wwii eg: black out lights, GI light switch flat colour paint and no chrome, R/H drive but it is a civilian cab.
the model numbers are W 4403, 4408, 4409 my truck is a W 4409 with stake sides
and the contract numbers are W-398-QM-12981
W-398-QM-13006
cheers Justin
