| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 68 | Hi all Just a quick question about where the small oil can spring loaded braket is suppose to mounted. When I removed it, it was on chassie rail on L/H side in engine bay but it looks like wrong place. My chev is a 42 1 1/2 ton truck R/H drive built for Australia Cheers Justin | | | | | Joined: Mar 2014 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 92 | Are you talking about an oil filter? I had a '40 Chevy 1 1/2 ton cab with a canister oil filter mounted on the firewall on the driver's side. JP | | | | | Joined: Jan 2010 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 68 | this is a little oil can used for maintenance, topping up oil in starter motor and generator it would hold approx 250 ml- or 1 cup oil. It also has EAGLE stamped on its side cheers Justin | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Justin, I have a salesman book to go with my '42 American Chevy pick up and there is no such oil can listed. That doesn't mean that it is not a correct factory item with a right hand drive export truck. I suspect, however, that your oil can is aftermarket or from some other vehicle.
I have seen oil cans on the firewall of cars from the late teens and early 1920s when there is no automatic lubrication of the rocker arms. The driver is required to stop and oil the rockers every 100 miles or so. Thus, a convenient oil can is mounted nearby.
Kent | | | | | Joined: Feb 2007 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 112 | That sounds like a Military part. They were big with having the oil can and bracket mounted on the firewall. Usually in the lower corner opposite the steering.(Pass. side) Could that truck possibly be Ex military? A lot of Dodge WC's had them. Just a thought, Tom | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Justin, Here is where the oil can bracket is located on a left hand drive 1941 Chevy. pic Paul
| | | | | Joined: Jan 2010 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 68 | thanks for the pictures of what the bracket looks like, my truck was built for wwii eg: black out lights, GI light switch flat colour paint and no chrome, R/H drive but it is a civilian cab.
the model numbers are W 4403, 4408, 4409 my truck is a W 4409 with stake sides
and the contract numbers are W-398-QM-12981 W-398-QM-13006 cheers Justin | | |
