1 members (Hanks custodian),
122
Mod | | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | I temporarily put a 15 X 6 - 6 bolt trailer wheel on my 54 to see how it looks. New 6 bolt trailer wheels are easy to find, built as a safety rim, available in a variety of sizes, and inexpensive. With an automotive tire mounted. I don't see a problem other than no provision for a hub cap. Am I missing something? | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | probably all you are missing is compliance to some DOT regulation. Trailers get subjected to heavy loads so if the strength rating is there, then they should be fine. maybe an insurance company would not pay a claim in the case of using "unapproved" wheels or you may be liable in an accident? in short, i don't think your concern is really with the hardware, but rather the software... | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Just my 2 cents here, I'd find the original wheels. I've even run the next generation rims 15", 55 to---? Your original hub caps should fit those that have the clips. Tons of rodders getting rid of those years, shouldn't be to difficult to put a set together. Best of luck | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Very difficult to find original 15" 6 lug with clips in my area. And very expensive. I prefer them to anything else.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | I got a set of 15x6 6-bolt tubeless trailer wheels from etrailer for right at $200 shipped. IMO it's the wheel deal of the century. Black powder coat of such depth and quality you can only make out the "trailer use only" stamping if you know where to look...that's how deep and glossy the powder coating is. Three nib design for many/most 60's-70's era hubcaps. I got some chevy bowtie poverty caps. Offset, backspacing, all were dead-on perfect. Rated well beyond truck's weight rating without all the costly regulatory crap required for passenger wheels. I'm running 215-75-15 tires and no worries with tubes because they have the tubeless bead ridge. Pics in my flickr link.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | Kinda makes me LOL thinking about DOT compliance. How many other things on our stovebolts would DOT, EPA, OSHA, NTSB, and others like to shut us down for. On a more serious note, I recently read an alarming article in a hot rod magazine. There are many bureaucrats who are working to regulate the old car hobby out of existence, forbidding any modifications of any kind. It's worth doing a little research on, and being aware of.... Just sayin' | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 |
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | redwing, sign up for the SEMA newsletter and they will help you stay informed about our hobby. I've written several letters to senators/governors due to them being informative.
...correct me if I'm wrong. Several years ago I thought the trailer tires were a odd ball size, as in 15 1/2, to keep folks from running the tires on vehicles???? Perhaps redwing used the tire and rim as long as the bolt pattern was right?
....but I must admit, back in the mid 60's, before the changes, I ran 6 ply trailer tires on my 56 coupe. They were about slick/worn out, and would really bite on the old slick "tar roads" around my home town. Won many drag races with them.
So, what is the skinny on trailer tires and rims? | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | I wouldn't run trailer tires, if for no other reason than smoothness of the Firestone Destinations...man, they're the quietest tires I've ever run on this truck!
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Jul 2004 Posts: 2,988 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,988 | Don't know about all trailers, but mobile home wheels are 14.5". Not sure if it's to keep those tires off cars or to keep car tires off trailer houses. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | In CO, you will be fined if trailer tires are used on vehicle.
Ed
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Here is an older thread on trailer rims. There was a lot of info that may be used in making your decisions. Have fun and good luck Dan | | |
