2 members (dt235sd, Bucker), 146 guests, and 0 robots.
Topics128,196
Posts1,057,390
Members48,471
When I removed the fenders I noticed the tires rub against the front springs when turned all the way. When I learned about this size tire I don't recall any mention of this. Fortunately I have not driven it very much. JC have tie rod ends that are a 1/2-inch shorter for this problem. Has anyone tried this or what are the other options? Thanks, Steve
It's probably not that bit of deal, you are normally moving really slow when steering to the far right or left. Take the load off the axle and turn to the far right and left and see if the tires hit, if they do adjust the steering stops, if they don't, the tires are just flexing. Adjusting the steering stops limits the turning radius, so only adjust to clear the springs and no more
ODSS President
ODSS President
I put over 100k miles on two sets of Michelins in that size. Yeah, I got that rub occasionally when I parallel parked, not an issue.
~ Cosmo
1949 Chevy Half Ton
Thanks Joe. I'll have to look in my manual to see how how to adjust the steering strips.
Thanks for your reply Cosmo. Steve
I've seen a number of cars that don't have adjustable stops. If needed we just weld a little puddle to the frame side of the stop.
Are stops and steering strips the same thing? Is that the steel band that goes around the spring? Some one is borrowing my manual is why I ask. Steve
I most likely am not following/understanding this discussion/problem.
1953 1/2 ton truck with basically standard/stock front-end parts?
Do you have the steering stop on the knuckle on each side, held in place with the king-pin lock-pin:
6.009 STOP ?
I have that size LT radial tires on my 54 31xx and they do not rub (original 6.50x16 wheels with 9/16" offset).
Tim, My truck is all original including a standard/ stock front end . I can't answer the second question as my truck is at the body mans place. With the fenders removed, I can see the tire lightly rubs against the steel band around the spring when turned all the way. This is the best way I can describe it. Steve
Steve,
If the stops are not there, you will get rubbing.
If the stops are there, I do not have any suggestions (sorry).
Good luck,
