2 members (JoergK., TUTS 59),
120
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | When I removed the fenders I noticed the tires rub against the front springs when turned all the way. When I learned about this size tire I don't recall any mention of this. Fortunately I have not driven it very much. JC have tie rod ends that are a 1/2-inch shorter for this problem. Has anyone tried this or what are the other options? Thanks, Steve | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | It's probably not that bit of deal, you are normally moving really slow when steering to the far right or left. Take the load off the axle and turn to the far right and left and see if the tires hit, if they do adjust the steering stops, if they don't, the tires are just flexing. Adjusting the steering stops limits the turning radius, so only adjust to clear the springs and no more | | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | I put over 100k miles on two sets of Michelins in that size. Yeah, I got that rub occasionally when I parallel parked, not an issue.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks Joe. I'll have to look in my manual to see how how to adjust the steering strips. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks for your reply Cosmo. Steve | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I've seen a number of cars that don't have adjustable stops. If needed we just weld a little puddle to the frame side of the stop.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Are stops and steering strips the same thing? Is that the steel band that goes around the spring? Some one is borrowing my manual is why I ask. Steve | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I most likely am not following/understanding this discussion/problem. 1953 1/2 ton truck with basically standard/stock front-end parts? Do you have the steering stop on the knuckle on each side, held in place with the king-pin lock-pin: 6.009 STOP ? I have that size LT radial tires on my 54 31xx and they do not rub (original 6.50x16 wheels with 9/16" offset). | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Tim, My truck is all original including a standard/ stock front end . I can't answer the second question as my truck is at the body mans place. With the fenders removed, I can see the tire lightly rubs against the steel band around the spring when turned all the way. This is the best way I can describe it. Steve | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Steve,
If the stops are not there, you will get rubbing.
If the stops are there, I do not have any suggestions (sorry).
Good luck,
