6 members (Samantha, tclederman, TUTS 59, Otto Skorzeny, Mike Roache, Steelonsteel), 48 guests, and 4 robots.
Topics128,036
Posts1,055,458
Members48,422
#119523 02/13/2006 12:35 AM
02/10/06 I picked up my cab and other parts from American Metal Cleaning today. Not sure that I could have been happier.
Photos - click here.
The cab looks great and only two surprises. Two additional holes
I was not expecting. Looks like there was very little filler used on it during it's many paint jobs over the years. It's pretty cool - the bolts that were froze tight are all loose now. If I ever do this again, the first step would be sending it in to get "cleaned" before battling the rusted bolts.
I'll be getting the patch panels from "metalman" installed and the entire thing primed in the next couple weeks.
As you can see in the photos below, I also had the steering & brake components done as well as the bell housing, valve cover and rear cab panel. All turned out great!!! Just look at the 01/01/06 entry on the brakes to see what a difference this makes!!!
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#119524 02/13/2006 1:13 AM
Lookin great Tim!
Now I am getting impatient to start the body work!
It probably said, but was looking at pictures instead...you had it dipped or media blasted or both?
#119525 02/13/2006 2:52 AM
Quote
I had it dipped.
Tim Sheridan
#119526 02/13/2006 4:46 AM
Nice pics, and great website Tim, cant wait to start on my 50 half ton, lots a work ahead, did the M-K bed kit work out allright? I need the front bed panel for sure, hope to get on it this spring. Mike
#119527 02/13/2006 9:59 AM
I know it is not polite to ask...but what did it cost you to get the cab dipped? I like what I see!
#119528 02/14/2006 4:56 AM
I think the cab was $950. The whole works was $1300. I know media blasting would have been cheaper but I wanted to make sure every nook & cranny was cleaned. Now i'm debating if I should have the frame dipped ($400) or go the more inexpensive route and have it blasted.
Tim Sheridan
#119529 02/15/2006 3:36 AM
Have you thought about getting the frame galvanized? My Chassis came out nice and they got to every hidded place on it and i didn't need to paint it after. Nice job on the cab!
#119530 02/16/2006 3:36 AM
Quote
Interesting thought. If you don;t mind me asking what does it cost to get a frame galvanized. I have considered e-coating and powder coating but I will likely just use zero rust.
Tim Sheridan
#119531 02/17/2006 12:59 AM
I'm no expert when it comes to galvanizing a truck frame but I am in the steel business and we have a large quantity of steel galvanized everyday. The steel is dipped into the molten zinc at a temperature over 850 degrees. If not handled properly there could be considerable warping. When we have fabricated frames or trusses there are special ways of dipping them.
Good luck. Typically galvanizing can cost anywhere from $.13 to $.25 per lb.
Brian
#119532 02/17/2006 1:58 AM
I checked with the local galvanizers on weather it would effect the chassis. he assured me that it would be ok (and it was) and showed me a 4WD chassis which had just come out of the process.
I liked the idea that i didn't have to paint the chassis and it wouldn't rust in the hidden places while i had to leave it outside until my cab was finished. it cost me about AUS$300, which i thought was worth it.
Brendon
#119533 02/24/2006 8:16 AM
That cab looked great Tim! I wonder if there is a place close to upstate South Carolina to have that done? I'd like to strip the cab and start with the good solid metal. What was the parts coated with afterward?
#119534 02/24/2006 6:43 PM
Truckwhisperer, not in upstate SC but if you don't mind the drive there's Unpaint in Atlanta GA. May be something else closer to you.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#119535 02/25/2006 3:57 AM
Truckwhisperer, I'm located in the upstate to. Are you close by?? Drop me a private message.
#119536 02/25/2006 5:13 AM
look under "metal cleaning" ni the yellow pages or in Google Local.
Tim Sheridan
#119537 02/28/2006 5:02 PM
Check Hemming's motor news, have seen some ads for stripping companies in there.
