0 members (), 83 guests, and 3 robots.
Topics128,081
Posts1,056,318
Members48,442
What's the best way to seat the race in the hub?
The race is just about 1/8" smaller diameter than 2" plumbing pipe OD, so I was thinking about modifying a short piece of pipe to tap the race into place.
Would a brass drift be a better or easier method? How about using length of all thread to pull it into place? Or should I just pay the machine shop to do it?
Probably not necessary to mention that I'm strictly an amateur back yard mechanic constantly learning new skills!
Thanks, as always. Jim
Brass drift will do just fine. Just be sure to move around the edge frequently. Been done that way in driveways all over the world.
secret
Thanks Martin! I've needed an excuse to buy yet another tool that somehow I don't already have. Off to town in the morning! Jim
I've used a piece of 2x4 many times to drive it down even with the hub and then use a socket to tap it on down a little....now that I have two nickels to rub together there is a seal/bearing kit out there that is not expensive....depending on how much "BRASS" is selling for these days you may want to look at the kit.
ODSS Lawman
ODSS Lawman
2x4
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Good advice on looking at a seal/bearing kit. I'll see what I can find when I go looking for a drift. Wouldn't hurt to have both.
Sweet, you got to love Stovebolt. I was thinking about a piece of plastic pipe, a brass drift was recommended, a fancy seal/ bearing kit sounded good and now just an old 2x4. Can't get much lower tech than that!
H Online: Content
Grind a few thousandths off the outside diameter of the old race and use it as a driver. I use a disc sander for that little operation. It's the best way to get a really good fit. A big socket can be used to extend the driver enough to prevent mashed fingers.
Big Bolt Forum Moderator
x2 on Jerry's idea. I do that all the time, then keep one I ground down in a drawer.
Mike
Hi Jerry & Mike, I guess that puts truth to the old adage about skinning cats!
