1 members (UtahYork),
117
Mod | | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | What's the best way to seat the race in the hub? The race is just about 1/8" smaller diameter than 2" plumbing pipe OD, so I was thinking about modifying a short piece of pipe to tap the race into place. Would a brass drift be a better or easier method? How about using length of all thread to pull it into place? Or should I just pay the machine shop to do it? Probably not necessary to mention that I'm strictly an amateur back yard mechanic constantly learning new skills! Thanks, as always. Jim
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Brass drift will do just fine. Just be sure to move around the edge frequently. Been done that way in driveways all over the world.
| | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Thanks Martin! I've needed an excuse to buy yet another tool that somehow I don't already have. Off to town in the morning! Jim | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've used a piece of 2x4 many times to drive it down even with the hub and then use a socket to tap it on down a little....now that I have two nickels to rub together there is a seal/bearing kit out there that is not expensive....depending on how much "BRASS" is selling for these days you may want to look at the kit.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 |
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Good advice on looking at a seal/bearing kit. I'll see what I can find when I go looking for a drift. Wouldn't hurt to have both. | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Sweet, you got to love Stovebolt. I was thinking about a piece of plastic pipe, a brass drift was recommended, a fancy seal/ bearing kit sounded good and now just an old 2x4. Can't get much lower tech than that! | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Grind a few thousandths off the outside diameter of the old race and use it as a driver. I use a disc sander for that little operation. It's the best way to get a really good fit. A big socket can be used to extend the driver enough to prevent mashed fingers. Jerry
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | x2 on Jerry's idea. I do that all the time, then keep one I ground down in a drawer. | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Hi Jerry & Mike, I guess that puts truth to the old adage about skinning cats! | | |
