| | | Forums66 Topics128,286 Posts1,058,583 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 1 Moderated | | Moderated Joined: Aug 2015 Posts: 1 | Got a stock 235 3 on tree 55 second 3100. It was sitting for about 35 years
Speedo cable was erratic screeching and broke the needle off speedo gauge
Replaced speedo cable with a new one. Still getting that erratic screeching.
Is it from the long unused instrument gauge or from the transmission where the cable threads in? | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | 55Chev2nd, technical questions are best answered in the garage forums. Since this is the Welcome Centre not everyone comes through here when they sign in. I'll move this to a garage forum where you can get some answers.
Welcome to Stovebolt. The place where you can get answers for your old Chevy and GMC's.
.....and watch for bolters from your state. I know they are here. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | welcome to the site! It sounds like a bad bearing in the speedo causing the cable to wind up like a spring and then send the speedo up to high speed in a hurry! | | | | | Joined: Feb 2000 Posts: 5,269 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,269 | Try a couple of small drops of oil on the back of the speedometer. You will need to remove the cable. The internal shaft of the speedometer may be dry and rubbing on the outer threaded portion. Sewing machine oil or 3 in 1 oil will do just fine. New cables shouldn't need any lubricant. | | | | | Joined: Aug 2012 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 28 | My speedo made awful chirping noises. I pulled it out and at the base where the cable screws on there's a small brass plug. Pulled the plug out and lubed it with atf. Plugged the hole with a lead fishing weight. No more noise! Been quiet for 3 years now.
1954 GMC 9314 - 261 t5
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The hole can be plugged with RTV sealant. | | |
