3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1186135 10/10/2016 12:12 AM
Moderated
Moderated
Got a stock 235 3 on tree 55 second 3100. It was sitting for about 35 years
Speedo cable was erratic screeching and broke the needle off speedo gauge
Replaced speedo cable with a new one. Still getting that erratic screeching.
Is it from the long unused instrument gauge or from the transmission where
the cable threads in?
55Chev2nd, technical questions are best answered in the garage forums. Since this is the Welcome Centre not everyone comes through here when they sign in.
I'll move this to a garage forum where you can get some answers.
Welcome to Stovebolt. The place where you can get answers for your old Chevy and GMC's.
.....and watch for bolters from your state. I know they are here.
Big Bolt Forum Moderator
welcome to the site! It sounds like a bad bearing in the speedo causing the cable to wind up like a spring and then send the speedo up to high speed in a hurry!
Mike
I could try the easy thing first. Get some of this stuff..
http://www.oreillyauto.com/site/c/d...73_1395266_-1&pt=C0073&ppt=C0338 Grease the cable and see if that fixes it.
Try a couple of small drops of oil on the back of the speedometer. You will need to remove the cable. The internal shaft of the speedometer may be dry and rubbing on the outer threaded portion. Sewing machine oil or 3 in 1 oil will do just fine. New cables shouldn't need any lubricant.
My speedo made awful chirping noises. I pulled it out and at the base where the cable screws on there's a small brass plug. Pulled the plug out and lubed it with atf. Plugged the hole with a lead fishing weight. No more noise! Been quiet for 3 years now.
1954 GMC 9314 - 261 t5
The hole can be plugged with RTV sealant.
