7 members (1955 1 Series, 3B, Jay R, Wayne67vert, Phak1, DaveV, Hush),
123
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | My mechanic looked over my truck (a while back for those keeping up, '53 GMC 3100) and recommended new kingpins. I finally got around to TRYING to take them off but the one I got to (left/driver's side) WILL NOT BUDGE. Yes, I took the retaining pin out. I tried some heat with what I have (propane torch) and busted out the BFH and a brass punch. Went at it about 2 hours and nothing. Tried hammering upwards and downwards to no avail. Any tips?? | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | How bad was the right side? I have heard of some guys having to take the axle out and have them pressed. I'll bet some savy bolter will come along with a better idea. Hang tight and keep them soaking in penetrant. | | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | Its easier to remove the axle and have the pins done at a machine shop if you don't own a portable king pin press | | | | | Joined: May 2015 Posts: 11,273 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,273 | Is the axle hanging in space or on the springs? You should solidly support it as close as possible to the kingpin. How big is your BFH? The bigger the better when it comes to driving pins out. There are rust molecules in there holding hands, and the idea is to make enough noise that they let go and cover their ears.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The BFH on kingpins can actually result in a bent axle. Support it solidly as close to the king pin as possible and give it a whack or three. If no movement you'll be better off pressings them out either in place if you can or remove the axle and take it to the press.
Whaling away with the big hammer for some time is not a good idea. | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I pounded mine out with a sledge hammer, years ago. What I discovered later was that the kingpins bulged a tiny bit on the top and damaged the holes in the axle. I eventually had to have hardened bushing installed in the axle to bring them back to standard. I would remove the axle and press them out.
| | | | | Joined: Feb 2000 Posts: 5,266 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,266 | Support the axle with heavy wood blocks, and give a couple really good whacks with the biggest hammer you have. If it starts moving, keep at it till you get close to the end. Keep measuring the pin before driving it out so you don't force the swelled out parts through the hole. You may have to grind down the pin or cut it off before continuing. Spray lube is you friend here along with heat. Switch your propane bottle to a bottle of MAP gas, it will get much hotter. The axle should almost be cherry red. I have had to drive pins out of school bus axle with sledge hammers taking full overhead swings, it's not a fun job!
Joe | | | | | Joined: May 2015 Posts: 11,273 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,273 | The BFH on kingpins can actually result in a bent axle. Support it solidly as close to the king pin as possible and give it a whack or three. If no movement you'll be better off pressings them out either in place if you can or remove the axle and take it to the press.
Whaling away with the big hammer for some time is not a good idea. Agree 100%. Also whaling away with a not big enough hammer is even worse. All that does is mushroom the pin.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2016 Posts: 226 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 226 | 1951 3100
I was waiting on the 'Heat' recommendation. Some will agree and some will not agree with heat. I personally had the spindles off my axle, put them in my press, and heated them, and heated them, sprayed some penetrant, and heated them some more. Used a rosebud, and was not shy using it. And after a while, it will start to release. You can hear the press starting to relax. Once it does, it's on then. They will come right out. The key, which more than one person told me, it to let the spindle cool on it's own.
I tried spraying them, letting them sit, and then BFHing them, but I'm not a big fan of that much banging. Something else may give, and not what you want. Bores cleaned up very nice, measured out correct, new bushings went in snug, king pins went in snug, and so far, everything is straight and true. Whole front end may collapse, but I don't think it will.
A press is the way to go. Just my 2 cents worth.
Mike
Mike
1951 3100 5 window
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've had them tap out as pretty as you please (not worn either) and I've had to use the press on others. Heat assist being last resort, some shop manuals warn against it. | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | I suppose I'll try to see if some c-clamp type press from the FLAPS will fit and do the job. Otherwise I'll pop off the axle and take it over to my mechanic to have them pressed out. Thanks for the help, fellas! | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Ball joint press did the job! Thanks for the tips everyone! Now for the bushings in the spindle... How do I get them out?? | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | They are a slip fit design, both on the king pin and the bore of the spindles. You should be able to easily tap them out, unless someone Loctited them to the spindle bores. In that case, some heat from a propane torch should make the Loctite let go. Carl
| | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Sounds straight forward enough. Does it matter which direction they go out? Also, I'm measuring because I don't know if oversize pins have been installed. Is the advertised measurement the measurement of the pin itself or the bore in the axle with/without the bushings?? Thanks for all the help! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Pin diameter, which is bore in axle, and bushing diameter in spindle after reaming, all the same within 0.001" or less. | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Everything measured up to standard size (.866). New kingpin set has been ordered. Thanks for the help! | | |
