1 members (Hotrod Lincoln),
92
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
Has anyone powder coated their hinges/springs? Does the coating last or will it flake off on the springs?
thanks, skipper | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | The problem will be getting the inside of the springs down to bare metal. This it the only way to make powder coating adhere to the springs long term. You also have the problem of the movement of the coils as they uncoil and recoil. Carl
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | sorry to disagree but I think they can and will be ok.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | as your local powder coating shop, the last thing they want to do is do a job for you that won't work or hold up and have their name on it. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I don't think it will flake off but some consideration of some other things are needed.
In MY experience powder coating is pretty dang tough overall. The problem will probably come in where the hinges "swivel" or slide together as they open and close. If your powder coating guy puts it on pretty heavy you will have a problem being tight. I had to cut some of the coating out of the edge of a belt tensioner and as Denny Graham would say "it tain't easy"!
I suspect the springs will do better than the hinges....and if you have to strip the powder coating off it is not an easy job. I know, I had to strip a set of big brackets!
Lastly, have a good talk with your powder coating man. He may have some tricks up his sleeve we don't know about. Just my .02 | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | The trick to getting most of the powder coating off is to use a torch and char it. Then a sandblaster or media blaster will take the charred remains right off.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd have them zinc plated or they can be plated black also. Check out D&B Plating in Minneapolis. I pickup and deliver parts to them from Polaris daily and they do fine work. It's much more durable than powder coating. | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Thanks for all the good advise. I would zinc them but in the bay area is seems difficult to find a shop that works on small scale non commercial stuff. | | | | | Joined: Mar 2013 Posts: 222 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 222 | I just had a set done for a 72 pickup that I was painting for a customer. these were new but you can glass bead them inside and out even the inside of the spring. we coated with silver it stayed on the spring but pealed at the hinge points. Jay D. | | | | | Joined: Jan 2015 Posts: 11 New Guy | | New Guy Joined: Jan 2015 Posts: 11 | I powder coated almost everything on my truck, but went with nickel plating on the hinges. The nickel is thinner than the powder and gets into the small crevices. I had a box of items coated (e.g. door striker plates, hood striker plate, hood hinges and springs, e-brake lever, etc) and the bill was about $50.
1949 Chevy 1/2 Five Window 2011 CTS V Coupe Michael Zahn
