Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Stewart2, Hanks custodian, Bill Hanlon), 116 guests, and 2 robots.
Topics128,286
Posts1,058,583
Members48,492
#1174657 07/19/2016 10:29 PM
The time has come to by a spare tire. My 215-85-16 won't fit on the side mount of my 53. I found a 195-80-16 is about the same as the orig 600-16 in diameter. I'm not sure if it will fit as far as width on the side mount. Anyone have a side mount with a wider than 600-16 tire.
basham #1174683 07/20/2016 2:26 AM
I just use a 600-16 tire for my side mount spare. It is a vintage Good Year bias ply tire. It holds air and looks cool, and will work just fine should I have a flat.
Carl
basham #1174726 07/20/2016 12:11 PM
Studs to short?
How about putting the wheel on backwards?
Or putting on longer studs?
Jeffrey
32vld #1174789 07/20/2016 11:52 PM
Well, I'm going to try something different. I bought a 155-90-16 doughnut tire today. Just a little smaller than the original and i'll mount it on the original rim then put a tire cover on it. Nobody will ever know and it should work. I'll let you know.
basham #1175696 07/27/2016 10:43 PM
Got my 155-90-16 tire mounted on the rim today and put on the side of the truck. Its about an inch smaller in diameter than the factory tire. It should work in an emergency. Looks fine.
basham #1175756 07/28/2016 5:05 AM
I took a Harley-Davidson branded whitewall, size MT90/16, mounted it on an artillary wheel and used it on my 54 GMC sidemount. Looks great and I'm sure it will do for a spare.
1954 GMC 9314 - 261 t5
basham #1175919 07/29/2016 8:20 AM
My spare is a can of Fix-A-Flat. If that fails my backup is the Roadside Assistance package on my car insurance.
1951 Chevy Panel Truck
basham #1176135 07/30/2016 6:03 PM
You could pick up some 6 lug spacers and with longer studs could mount just about any wheel. Best of luck
1946 1/2-Ton Chevy
