1 members (klhansen),
107
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,856 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | The time has come to by a spare tire. My 215-85-16 won't fit on the side mount of my 53. I found a 195-80-16 is about the same as the orig 600-16 in diameter. I'm not sure if it will fit as far as width on the side mount. Anyone have a side mount with a wider than 600-16 tire. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I just use a 600-16 tire for my side mount spare. It is a vintage Good Year bias ply tire. It holds air and looks cool, and will work just fine should I have a flat. Carl
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Studs to short?
How about putting the wheel on backwards?
Or putting on longer studs? Jeffrey
| | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | Well, I'm going to try something different. I bought a 155-90-16 doughnut tire today. Just a little smaller than the original and i'll mount it on the original rim then put a tire cover on it. Nobody will ever know and it should work. I'll let you know. | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | Got my 155-90-16 tire mounted on the rim today and put on the side of the truck. Its about an inch smaller in diameter than the factory tire. It should work in an emergency. Looks fine. | | | | | Joined: Aug 2012 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 28 | I took a Harley-Davidson branded whitewall, size MT90/16, mounted it on an artillary wheel and used it on my 54 GMC sidemount. Looks great and I'm sure it will do for a spare.
1954 GMC 9314 - 261 t5
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | My spare is a can of Fix-A-Flat. If that fails my backup is the Roadside Assistance package on my car insurance.
1951 Chevy Panel Truck
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You could pick up some 6 lug spacers and with longer studs could mount just about any wheel. Best of luck | | |
