0 members (),
110
7
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | My 63 c10 had fuel starvation problems, Upon pulling the fuel tank sending unit, I see the fine screen intake filter clogged with very very fine fine particulates. That looks to be the culprit. However, it made me wonder, with this lower intake filter, is an upper inline filter doing much? I mean, it would have to be a very very fine particle to pass thru and make it up to my simple old one barrel carb.
Really, I think that carb will never be affected by anything the intake filter passes on. I don't like add on filters, they never look original and on this motor, placement - with original fuel line configuration- isn't that simple. Opinions? | | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | I run one on my '65 C10, cheap insurance against a simple issue.
dunno what the setup was on an original one tho'.
-W
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | The fine particulates you are finding on your fine screen may very well be deposits. This means that some of this material is actually getting past the screen heading toward the carburetor. This material may currently be coating the inside of the tank and continue to be an issue in the future. An inline filter will give you added security, and a good way of discovering whether what I just suggested is actually occurring. Carl
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | In my humble opinion, an inline filter is absolutely necessary in our old trucks, and offers cheap insurance against costly repairs. Even though a carb rebuild kit isn't expensive, my time certainly is. And you can't put a price on loss of performance either. Only possible reason for not using one would be if you had a brand-new fuel tank and new fuel lines, and even then I would still have an in-line filter just to be on the safe side.
Just my two cents worth.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Carbs aren't cheap but a filter is. I don't have a filter inside my 52panel tank but I have one coming out of it, and one between the fuel pump and carb.
....my 37 stopped on me while on I-85 one hot summer evening. Pulled the filter and was on my way in 20 minutes. Put them where you can get to them easy. Also never know what you get at the gas station anymore. | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Carbs aren't cheap but a filter is. I don't have a filter inside my 52panel tank but I have one coming out of it, and one between the fuel pump and carb.
....my 37 stopped on me while on I-85 one hot summer evening. Pulled the filter and was on my way in 20 minutes. Put them where you can get to them easy. Also never know what you get at the gas station anymore. Agreed. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Carbs aren't cheap but a filter is. I don't have a filter inside my 52panel tank but I have one coming out of it, and one between the fuel pump and carb.
....my 37 stopped on me while on I-85 one hot summer evening. Pulled the filter and was on my way in 20 minutes. Put them where you can get to them easy. Also never know what you get at the gas station anymore. agreed x2 | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I have a new tank and lines and I still run 2 filters 1 before the pump and 1 at carb. root | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | "Never look original"? If you hide them in the frame, then you get the look you want. DADS50 has a cool filter that threads onto the carb as sort of original. WIX 33081 or equivalent.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The period correct filter would be a glass bowl type
Lonniec has a thread with good info and pics
I run a filter under the tank, Was having flooding issues so added a second at the carb A recomendation from a member here
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hid one of my filters to the flex line on the chassis. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0167.jpg...I plan to stop at O'Rielly's tomorrow for the Wix 33081 for my 261 in the coupe. I checked online and think they have it for $4 if I remember right. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | The period correct filter would be a glass bowl type Where was the period correct filter mounted? | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The nice part about the original style glass bowl fuel pump was it has a screen that prevents alot of particles from getting through to the glass bowl fuel filter at the carb. If you have those to items, I do not see a reason to have another filter between the tank and the pump.
If you don't have the screenage at the pump, it's a very good idea to use an inline filter before the pump. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thanks. It always seemed that the filters mounted right above the hot exhaust manifold was not the best idea. They do look nice though. I have a few, but do not have the will to cut my fuel feed line. | | |
