| | | Forums66 Topics128,196 Posts1,057,393 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I have a 1949 3100 and am thinking of installing the passenger side rear view mirror. I am hoping that a 'bolter has one and can give me the location dimensions to mount one of these.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Not sure about the 49 but look under the dash at the area where the mirror should mount. There should be a reinforcement piece of metal there with holes in it to match the placement of the mirror. My 52 has them so perhaps yours does too. It should look something like this...disregard the hole for the antenna which the PO had on the passenger side. Hope this helps. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/100_1398.jpg | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brad, just-a-hacker might be referring to this style mirror arm, which I think that Alvin is referring-to? I think your template might be for a different style arm? Maybe your template will work for both style arms (and the holes are over the holes in the under-dash brace)? If they are the same template, if you are willing to mail the template to me, I'll scan it as a real-size PDF image and post a link to it. I'd, of course, mail the original back to you. Thanks,
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The hole to hole dimension is the same, I used it to mount mine which is the small curved arm type. Tim, I return to the states on Friday, PM me your address and I will send both directions and template for you to copy. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yep, I edited that postulation while you were posting.
Check my offer, above.
