Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (3B, 1955 1 Series), 36 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1157015 03/27/2016 2:20 AM
I recently rebuilt a 1950 216 with a lot of help from folks on this forum. I have it on a stand so I can run it a bit before I cover it and work on other parts of the truck. While running it today I noticed 4 of the push rods have some "wobble" ( valve cover is off and side cover is on so can't see much). One moves very near the hole in the head! Is there an amount of movement that is acceptable? Should I replace the ones that are not straight or all them?
Jackie
JackieC #1157036 03/27/2016 3:10 AM
Any flex/bend at all will get worse. If you have access to a lathe you can set the pushrods up between centers and straighten them, using a small dead-blow hammer and a dial indicator. Get an overall length measurement- - - -I might have some stashed away that are straight and the right length.
JackieC #1157042 03/27/2016 3:21 AM
.....or you may want to post an ad in the parts wanted forum. surely someone close by has some extra's.
Achipmunk #1157059 03/27/2016 4:59 AM
' Offline
1950 216 6 cyl. uses GM Pushrod
GM # 0.426
GM # 3835776 - 10 & 7/16 " O.L.
They are available GM NOS
Friesen's Chevrolet
Sutton, Nebraska
phone: 402-357-5538
Friesen's has ( 2 ) GM NOS - GM # 3835776
Dan's Obsolete
Chinook, Montana
phone: 406-357-2615
Dan's has ( 12 ) GM NOS - GM # 3835776
There are ( 10 ) GM NOS pushrods on ebay now for
$12.00.......they can be cleaned up.
photo@photobucket
http://i669.photobucket.com/albums/...%20NOS/3835776%20%20%201_zpsoheu16ku.jpg
http://i669.photobucket.com/albums/...s%20GM%20NOS/3835776%202_zps51wdehqw.jpg
Go to ebay & type in the search box: 3835776
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
JackieC #1157070 03/27/2016 11:57 AM
I picked up pushrods a few years ago at my local autoparts store.
...pic...
...take your bent one to compare...
Did some measuring this morning------.250 diameter and 10.499 inches long (measured with a digital caliper)
Jackie
DADS50 #1157079 03/27/2016 2:29 PM
Wow....mine are not bent quite that bad...yet anyway.
Jackie
JackieC #1157102 03/27/2016 4:47 PM
Watch your mailbox- - - -I just found a full set of correct-length pushrods for your application left over from a recent horsetrade!
JackieC #1157103 03/27/2016 5:04 PM
Awesome!!!
I'll keep an eye on the box!!
Thanks Jerry,
Jackie
JackieC #1157105 03/27/2016 5:18 PM
I have some NOS 235 High torque pushrods, as I remember they are just slightly longer than the 216. These were old military surplus parts.
1946 1/2-Ton Chevy
JackieC #1157113 03/27/2016 6:03 PM
The splasher 235 block has a taller deck height to compensate for the longer stroke, which requires longer pushrods.
