2 members (Otto Skorzeny, LAROKE), 82 guests, and 0 robots.
Topics128,050
Posts1,055,672
#1155029 03/15/2016 1:08 AM
1 Offline
my casting number is 3837004 which to my understanding is a 55-57 235 but also cast into the block just to the right of the casting number is the word SPECIAL
1952burb #1155670 03/18/2016 10:34 PM
1 Offline
TTT
1952burb #1155702 03/19/2016 1:32 AM
1955-1957 car 235 block casting code: 3837004
It should have hydraulic lifters.
Can you post a link to a photo of that 235 block casting code and "SPECIAL"?
What is the Engine Serial Number that is pressed into the block to the rear of distributor?
1952burb #1155721 03/19/2016 3:33 AM
I would like to see some pictures also.
My Blog
1952burb #1155796 03/19/2016 10:31 PM
Sounds interesting to me. Get some more posts so you can can get us some pictures!
1952burb #1155822 03/20/2016 3:22 AM
1952burb, you now have enough post to post some pictures. We are all getting anxious to see them. Thanks.
1952burb #1155826 03/20/2016 4:02 AM
Did that "special" engine come out of a short bus?
1952burb #1156073 03/21/2016 5:32 PM
Pictures please. From a short bus? Might be a 261? Nothing wrong with the bus. Short is cool.
Steve H
1952burb #1156140 03/21/2016 11:22 PM
1 Offline
sorry been busy the last few days. the numbers pressed into the block by the dist. is FI008A which I know the I is actually a 1 from other threads on here. bear with me on the pics
1952burb #1156145 03/21/2016 11:29 PM
1 Offline
I took some pics i'll try to get them posted. im what some would call computer illiterate so it might take a little bit
1952burb #1156146 03/21/2016 11:32 PM
Put the pictures on your favorate picture hosting web site like Photobucket and copy the picture link address and paste it here...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
1952burb #1156166 03/22/2016 1:17 AM
1 Offline
1952burb #1156170 03/22/2016 1:22 AM
http://ncm_0071/
link does not work
1952burb #1156175 03/22/2016 1:29 AM
1 Offline
1952burb #1156179 03/22/2016 1:36 AM
Same address: http://nmc_0072/
link does not work
1952burb #1156181 03/22/2016 1:40 AM
1 Offline
ya I know im sorry I finally figured out how to get them om my computer with photobucket but the url which I assume is the letter and number sequence at the bottom of the photo. i type it into the http box and it tells me it cant reach this page. so im am lost
1952burb #1156222 03/22/2016 3:40 AM
the URL [Uniform Resource Locator] is the address in your browsers address bar when you're at pbucket looking at the picture, like HTTP/www. whatever in the address of this forum page
1952burb #1156224 03/22/2016 3:44 AM
Go to your picture in Photobucket and copy and paste the entire picture link at the top of your screens (the www.xxxxx). Put the curser on the address, Left click and it should hi-lite the entire address, then Right click and copy. Carry it here and then right click and Paste...done!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
1952burb #1156230 03/22/2016 3:56 AM
1952burb #1156240 03/22/2016 4:46 AM
Dads50,
Great job with that YouTube video on linking pictures!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
DADS50 #1156295 03/22/2016 2:40 PM
That tutorial was outstanding, thanks for sharing. Hope our friend gets that link , I'm curious as heck about this "special" 235......kind of like a good mystery novel.
Ron - - Dusty53
1954 Chevy 3604
1952burb #1157483 03/29/2016 6:29 PM
1 Offline
http://s1155.photobucket.com/user/brandong81774/library/?sort=3&page=1 OK guys after I finally got some help I think I finally got them on here for you. and sorry it took so long
1952burb #1157491 03/29/2016 7:14 PM
V
V Offline
Yep, looks cast special to me. Very interesting grin
1952burb #1157494 03/29/2016 7:42 PM
1952burb,
That certainly is SPECIAL.
What is the block date casting code?
1952burb #1157514 03/29/2016 10:19 PM
I would like to know the history, or pull it apart.
My Blog
1952burb #1157548 03/30/2016 1:42 AM
Weird.
Some kind of " test" casting or something?
1951 3100
1952burb #1157620 03/30/2016 2:47 PM
1 Offline
the block date casting is con4 j26 which I'm thinking is oct 2 1956 I'm guessing and the engine serial number is FI008A which I do know the I is a one. don't really know the history other then that's what came in it when I bought it.
1952burb #1157622 03/30/2016 3:06 PM
Most likely it (the "6") is not indicating "1956".
The format for Engine Serial numbers in 1956 was different.
Regarding the "A" in : FI008A
The A indicates a car engine (engine in a car with a standard transmission).
The block most likely had hydraulic lifters (but, it could have been used with mechanical lifters).
My bet, now, is that you have a factory replacement engine that was cast after 235s were regular equipment, perhaps cast in 1966 (maybe in 1976, if GM was still making replacement 235 blocks in 1976).
Maybe someone else has other explanations/postulations/speculations?
Do not get rid of that block. Even if it is bad, someone might want want it for its "peculiarity value".
1952burb #1158177 04/03/2016 12:36 AM
1 Offline
no sir I don't plan on it! its actually still good was froze up when I got it but got it freed up and running somewhat wont stay idling for some reason. now I think I've got the timing messed up.
1952burb #1158178 04/03/2016 12:38 AM
1 Offline
thanks for the input on it. if i ever find out anymore ill post it for you guys
