5 members (Shaffer's1950, Gdads51, Otto Skorzeny, Wayne67vert, Hotrod Lincoln), 96 guests, and 1 robot.
Topics128,139
Posts1,056,454
Members48,441
#1146727 01/27/2016 12:21 AM
Is there any other seat that will fit in a 1936 low cab pickup? I have seen pictures of what I think was a 1937 seat in a 36 but what I have read the 37 was split bottom because of the gas tank under the seat. I guess that would be alright if it fit my 36?
The seat for the 1937 GMC was different than the 1936 GMC, since they used the same cab as the Chevrolet I would guess that the same would apply
1936 GMC T-14 1/2-Ton Pickup
Thanks for the quick answer, guess I'll keep looking for the real McCoy. Nice looking truck by the way.
True '37 bottom seats are spilt. Had to raise the passenger side half up to put gas in the 1/2 ton 37. Mine is till that way!.
That is what I understand to, but will a 37 seat fit in a 36? Will any other year fit my 36 low cab?
Does anyone have good pictures of the 36 seat, top, bottom, pics of the frame and springs, mounting hardware if any, how it attaches to cab, I don't know anything about the seat for my truck, just need info so if I find one I will know what to look for.
thanks for the help
Any good upholstery shop should be able to make that simple seat from a photo. May be the best way to go as the stock ones today may not be good for anything but a pattern.
Best of luck
1946 1/2-Ton Chevy
I know a real good upholstery man, but I think it would help to have some pics and some dimensions of an original one, if any body can supply them to me. That way when I'm at a swap meet and happen to get lucky and spot a set, I'll be ready to snag them up.
theres a 37 seat on ebay now
Old Indy, you may want to PM Joe "6cylindersovertexas". He knows a lot about 37 and I'd bet he can answer your direct question.
Thanks but I don't know how to use the directory to find his email address. What's his display name?
I found it and sent him a note
Old Indy, pm your email address and I will send you measurements and photos of my seat.
Moderated by  ndkid275, Phak1
