7 members (Otto Skorzeny, Hotrod Lincoln, Slick Willy, 1955 1 Series, GrandpasJimmy, BarryP, 1 invisible), 95 guests, and 1 robot.
Topics128,162
Posts1,056,925
Members48,458
Hey all
I have a 5.7 Chevy 350 in my 48 3100. It's got a holley carb on top. I just wondered if anyone knew what length the throttle cable is as I need to order a new one for it
beep beep beep truck update
It's going to depend on where your engine is mounted, what pedal you're using and where it's mounted, etc. Lokar makes a good kit.
My 46 GMC on Photobucket
Used a lokar with my 305 52panel and have never looked back. Works nice.
The Lokar cables I've looked at on Summit can be cut to length. This is spelled out in the details of the part.
What are you using for a pedal?
http://www.summitracing.com/
1946 1/2-Ton Chevy
Ditto on my '40 with SBC. Use the Lokar kit. Cut to length. Finished product looks good, had good brackets included.
1940 Chevy KC 1/2-Ton
