| | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 12 New Guy | | New Guy Joined: Dec 2015 Posts: 12 | Hey all
I have a 5.7 Chevy 350 in my 48 3100. It's got a holley carb on top. I just wondered if anyone knew what length the throttle cable is as I need to order a new one for it
beep beep beep truck update
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It's going to depend on where your engine is mounted, what pedal you're using and where it's mounted, etc. Lokar makes a good kit. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Used a lokar with my 305 52panel and have never looked back. Works nice. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The Lokar cables I've looked at on Summit can be cut to length. This is spelled out in the details of the part. What are you using for a pedal? http://www.summitracing.com/
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Ditto on my '40 with SBC. Use the Lokar kit. Cut to length. Finished product looks good, had good brackets included. | | |
