3 members (Gdads51, Bill Hanlon, Otto Skorzeny), 65 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#1137894 12/05/2015 4:45 AM
Has anyone had luck installing the rubber around a crank out windshield? I destroyed 1 piece of rubber already. It was an a long strip, but i see I can buy a 1 piece rubber gasket also.
Any help or advice would be greatly appreciated!!!!
I've put a couple around the windshield of my 37 twice in the past 17 years. No problem. I think the 37/38 are the same. What do you think the problem is??....or at?
back yard wrench turner
I had no problem installing the seal around mine. I have a new windshield frame and a new gasket.
Did you lubricate the gasket before inserting it into the frame?
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
The one I bought from Jim Carter was hard and inflexible. Gave up after a few days of fussing. Ordered another from Steeles Rubber Products that was great. It has a butt joint to fit and glue, but works fine. Steeles can give you the name of the proper 3M adhesive to use on the butt joint.
1940 Chevy KC 1/2-Ton
I did not lubricate the seal. I got it form a gasket dealer at a car show, & he sold it to me with 3M Adhesive. I was instructed to use the 3M in the channel, relief cut the corners and glue them with CA as well as the joint. One big mess later I gave up.
