| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 29 | Has anyone had luck installing the rubber around a crank out windshield? I destroyed 1 piece of rubber already. It was an a long strip, but i see I can buy a 1 piece rubber gasket also.
Any help or advice would be greatly appreciated!!!! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've put a couple around the windshield of my 37 twice in the past 17 years. No problem. I think the 37/38 are the same. What do you think the problem is??....or at? | | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | I had no problem installing the seal around mine. I have a new windshield frame and a new gasket. Did you lubricate the gasket before inserting it into the frame? Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | The one I bought from Jim Carter was hard and inflexible. Gave up after a few days of fussing. Ordered another from Steeles Rubber Products that was great. It has a butt joint to fit and glue, but works fine. Steeles can give you the name of the proper 3M adhesive to use on the butt joint. | | | | | Joined: Nov 2012 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 29 | I did not lubricate the seal. I got it form a gasket dealer at a car show, & he sold it to me with 3M Adhesive. I was instructed to use the 3M in the channel, relief cut the corners and glue them with CA as well as the joint. One big mess later I gave up. | | |
