9 members (Gdads51, jmoore, King Kielbasa, cmayna, 2-Ton, Danielbolt, JW51, Rusted Nut, 1 invisible),
86
Mod | | | Forums66 Topics128,169 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | First off the one I have is NOT rusty which may change the approach to cleaning. Today I took the float out and what I see inside is probably "wax" left from the gas evaporating. It did have a little stale gas in it but not much.
I used a long screw driver to see what would happen and it will "scrap" off and underneath is nice shiny metal. I poured a little purple power in the tank and it seems to soften it. Since I can't get to it I need something to DISOLVE IT.
What do I do...pour some new gas in to see if it'll "re-constitute"? ... or something you guys have tried and works good. Thanks. | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Grab a shovel and find a pile of clean gravel somewhere. Funnel a couple of shovelfuls of gravel into the tank, followed by a STRONG mixture of laundry detergent and water, then seal up the openings and strap the tank down in the back of a pickup truck. Now, take a long, leisurely drive on a twisty back road. When you get back, the tank will be scrubbed clean and all you'll have to do is get the soapy water and gravel out of it. Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...jerry, thanks, I thought about strapping it to a tractor tire but I sold the old 8N sometime ago!
I'm just being cautious. I use to work with a LOT of dangerous stuff when in printing and plating ect.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I wasn't that keen on flushing out gravel as Jerry suggested  so I used several chunks of chain when I did mine. Worked quite well.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Alvin, I think you want to scrape off the tin plating so if you've just got stale gas residue pouring a gallon of Gunk carburetor cleaner in it and sloshing it around then letting it sit for a few hours might do the trick. Every serious gear head has a gallon of Gunk Carburetor cleaner sitting in the corner, don't they??? Heck, I've got three.
I've been soaking my pistons in it over night and it does a pretty good job at removing most of the oil stains. Of course the really baked on stuff above the top ring and on the dome still needs a little more care. That's where the Soda blaster comes into play.
dg
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | OK guys, thanks for the input. I think a combination of all of the above may be in order. I just can't get to it so its got to be a good solution to "melt" that crude. The tank is in great shape and even if I could find a radiator shop to boil it out I'm not sure they wouldn't do more harm than good. So CLEAN CLEAN CLEAN it is. I'll plug off the holes so I can turn it every which way but loose!
I have gravel, I have chain, I have purple power, I have a gallon of cleaner and a pickup truck....looks like I'm all set! | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Pine Sol has been used. Dilute by half with some very hot water. Get the tank warmed in the sun and pour in the hot solution. After it cools, pour it out and heat it up again and reuse. Never tried it myself. Just read about it. Adding the chain or gravel should help too. I think getting a HOT solvent inside will help a lot to dissolve it.
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | The hole for the sender is the flattest "drain"opening you have. It will also accommodate a shop vac hose to remove any "gravel" residue that might remain.
Steve H
| | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Chance of sucking gas fumes through a vacuum cleaner with a electric motor, sounds kind of dangerous to me.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Maybe before washing and rinsing the tank....
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | After the final rinse, I use a leaf blower to dry it quickly to minimize rust. | | | | | Joined: May 2015 Posts: 11,142 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,142 | Back when I restored my Model A, I cleaned the tar out of the gas tank with a gallon of lacquer thinner. It dissolved it in no time. That might be worth a try.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Good point on the shop vac and fumes. I had assumed(ouch) soap and water was part of the "cleaning" process. If you go to the effort of removing the tank and have cleaned the inside with some sort of abrasive(sand, gravel, or what ever) I would have thought flushing and washing would be part of the clean up. Still, better to be safe at all times.
Steve H
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Carb cleaner if it isn't rusty. | | | | | Joined: Apr 2015 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2015 Posts: 58 | I used MEK to clean my tank and it worked great! YMMV. Best regards, Les | | | | | Joined: Jul 2015 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 54 | I have cleaned rusty dirty tanks with washing soda and a battery charger. There are you tube videos on how to do this. I have had great results saving a few tanks that were heading for the junk. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Elton, there is a tech tip here on the bolt about that. I may not spell it right but its called electrolysis..... | | |
