4 members (tclederman, Shaffer's1950, treegrower, Buckeye998), 337 guests, and 2 robots.
Topics128,152
Posts1,057,012
Members48,460
1 Offline
1st time on Stovebolt. just purchased a 1939 chevy 1.5 ton . has a 1948 6cyl engine . I am removing all the wiring and weather stripping. the engine runs , the clutch needs replacing. hardly any rust. just learning about the truck, I realy like the body style. I am hoping to get aquainted with eveyone about stovebolt .
3B Offline
Hy 1pete1, welcome!
Welcome!
You came to the right place. Ask away with your questions and show us some pictures when you can.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Welcome. Good luck with our truck. I have a 1940 1.5 Ton that my grandfather bought brand new. It only has 21,000 original miles on it. I learned to drive on this truck and it is one of my prized possessions. If you have any questions just let me know. Al.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
1 Offline
hi Rich, my 1939 chevy has a 1948 engine , I am trying to locate a carberator for it, some one tried to rebuild it and stripped the screws , leaks and runs poorly, thank you
1 Offline
hi Alkay3, I am looking for a carberator for a 1948 truck engine what years all interchange ? this is for my 1939 1.5 ton . previous person titened the screws to tight stripped and now leaks . thanks 1pete1
your local parts supplier can probably get the carburetor. Jim Carter in the links section can get carbs c.heck the links section on this site likely a Rochester carb. originally. My 38 had a carter W1 but the 54 has a Rochester. Bolter carbking may be able to answer your question check the engine forum.
The 1948 engines had Carter W1s.
