| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 94 | 1st time on Stovebolt. just purchased a 1939 chevy 1.5 ton . has a 1948 6cyl engine . I am removing all the wiring and weather stripping. the engine runs , the clutch needs replacing. hardly any rust. just learning about the truck, I realy like the body style. I am hoping to get aquainted with eveyone about stovebolt . | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | | | | | | Joined: Jul 2004 Posts: 2,991 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,991 | Welcome! You came to the right place. Ask away with your questions and show us some pictures when you can. | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | Welcome. Good luck with our truck. I have a 1940 1.5 Ton that my grandfather bought brand new. It only has 21,000 original miles on it. I learned to drive on this truck and it is one of my prized possessions. If you have any questions just let me know. Al. | | | | | Joined: Oct 2015 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 94 | hi Rich, my 1939 chevy has a 1948 engine , I am trying to locate a carberator for it, some one tried to rebuild it and stripped the screws , leaks and runs poorly, thank you
| | | | | Joined: Oct 2015 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 94 | hi Alkay3, I am looking for a carberator for a 1948 truck engine what years all interchange ? this is for my 1939 1.5 ton . previous person titened the screws to tight stripped and now leaks . thanks 1pete1 | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | your local parts supplier can probably get the carburetor. Jim Carter in the links section can get carbs c.heck the links section on this site likely a Rochester carb. originally. My 38 had a carter W1 but the 54 has a Rochester. Bolter carbking may be able to answer your question check the engine forum. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 1948 engines had Carter W1s.
