3 members (Gray_Ghost, DadsFirstPickup, moparguy), 102 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
Apprentice
Apprentice
I saw a 1950 pick up on the net with a fuel tank mounted between the frame rails I think it was a blazer tank has any one done this I dont like the thought of the tank in the cab I am also a need to move my seat back some for leg room and keep my belly from hitting the stock steering wheel Im only 245 lbs im sure some one back in 1950 weighed this I cant be the first with this problem Thanks Tim
You'll only gain about an inch, if that. Some move the tank to the rear thinking it's safer. As long as your tank and connections are in good shape, the cab is as safe as any place.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I mounted a Blazer tank in my '50 for they same reasons as you mentioned. At 6'5" 260lbs even an inch is worth it to me. I will also more than likely have to mount the seats a little higher so that I can stretch out a bit more. The tank swap was very simple. I used a tank from a military Blazer with a 25 gallon capacity. I have not decided if I'll run the filler through the rear fender or the bed.
Robert C.
I'm a Genius in the making.
1950 3600
Jim & Caroline
I plan on mounting a blazer tank in the rear of my truck as i hate the fumes in the cab.
Moderated
Moderated
I'm doing the S10 frame swap with a 42 pick up. I thinking about moving the tank to the back and using the 4DR Blazer tank. I've read posts on this forum and the S10 forum, and it's been done. I'm wondering if instead of going the wide side between the frame rails, if it's possible to rotate it and have the filler tube facing the rear, instead of the side. It would give more room for dual exhaust. Has anyone tried this? It looks like it'll work.
