4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#11145 06/22/2004 2:59 AM
OK, maybe I am asking this question in the wrong forum.
I have a 46 Chevy 1.5 Ton Flatbed/Stake truck.
I need to know how much it weighs.
I need to purchase a car hauler for it and I don't want to smash it flat with a heavy truck.
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
#11146 06/22/2004 3:31 AM
My guess, depending on the weight of the box, would be around 6000 to 7000 lbs. My truck with around 3 ton of gravel on weighed 12,500lbs.
Just a guess,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#11147 06/22/2004 3:49 AM
Safest bet would be to take it to a truck scale and weigh it...
The Restoration Pack from Chevrolet for a '48 would tell you what it should weigh but the bed configuration could make a lot of difference, so that number would only be an estimate.
#11148 06/22/2004 4:00 AM
tT be "on the money" take it to a truck stop that has a set of certified scales. I did that with my 37 pickup since I had made modifications to it.
The place I went to charge me 5 bucks and gave me a certified ticket. Then you will know EXACTLY. smile
#11149 06/22/2004 4:27 AM
I have an Art Deco Truck Sales Data Book. If you can tell me the wheelbase, whether you have single or dual rear wheels, and if it is a conventional or cabover, I can give you the curb weight according to the factory.
#11150 06/23/2004 3:22 AM
Today I got you an actual weight on a 1.5 ton truck. I was haulling gravel today and had the truck weighed empty. It's a '48 1.5 ton truck with a 12' grain box with sides and a single cylinder hydraulic lift. PTO drive and a 240 lb. driver, the truck weighed 7360 lbs.
Just thought you would like to know,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#11151 06/23/2004 11:10 AM
I took my 45 Chevy 2 ton to the scrap yard recently to drop off a load of junk.The truck with a full tank of gas weighed 4460 lbs empty.This is a 134 inch wheelbase,all oak 9 foot flat bed. A 1-1/2 ton is slightly lighter.
