3 members (JW51, Otto Skorzeny, 1 invisible), 112 guests, and 4 robots.
Topics128,269
Posts1,058,402
Members48,485
#1113931 07/16/2015 1:48 AM
Does anyone have a picture of the cloth molding (similar to the one on the cowl) that goes at the front of the hood? I don't know the correct name for the small filler panel that attaches to the fenders, but these go on it under the hood. Thanks, Scott
Scott, IF I understand you correctly I honestly don't know. However, on my 37 I used the same stuff that went across the cowl on the front edge of the radiator surround that the front of the hood fits against. I just don't remember if I just used it or that was what was originally used?. I may be totally wrong.
I think you are talking about the fender extensions. I used the same material that I used on the rear of the hood. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
back yard wrench turner
Hood lacing is what it's called. I had my wife sew some for me. She used a small diameter rope and something like duck cloth.
I don't know if anyone makes it.
I can take a photo tomorrow in the daylight if you want.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I know it belongs there, there were small pieces of it held on with small clutch head screws. I just don't know what they did on the ends, how long etc. There are slots at the top and bottom but I don't know if they are used in any way. A picture of it installed or still in tact would be very helpful. Thanks Scott
I think this is the stuff. Also, I believe the lacing tucks in the slot and is held in place with a screw on the engine side. Been a while since I've seen a truck with this stuff, looks correct and has a vintage look over the rubber stuff.
http://stores.restorationspecialties.com/flat-hood-lace/
1946 1/2-Ton Chevy
I reread your request. Mine doesn't have the front hood lacing.
This rear lacing is mine installed but not to VCCA standards.
click
Wayne
1989 Silverado
I don't have any closeup pictures, but can describe it:
The lacing was fabric and had three ribs, unlike the widely available reproductions which have two ribs.
Unlike the lacing on the cowl, there was no wire running down the middle.
The sections were held in place with two hex/clutch head screws with no washers or other devices to clamp the lacing down.
The lacing was long enough to poke through the two slots at the top and the bottom and maybe 1/4" to 3/8" went through to the other side.
If you click on pics of my 46 one shows the lacing at the front of hood.
1946 1/2-Ton Chevy
Thanks guys, I had just enough left from the cowl. Looks great! Thanks, Scott
