2 members (Donf, Gray_Ghost),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | I've read some old threads that talk about how topple-prone stovebolt are on a stand. This looks better than those three leg things, but need some advice. Rated for 750 lbs and listed on CL. Stand
1951 3100
| | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | Think it will be safe enough to use?
1951 3100
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | JW51, while I don't specifically like it, I am currently using a 3 wheel engine stand. Currently I have a 283 on one stand and a 261 6cyl. engine on another. It is however not one of the "cheap" ones. Its a heavier duty one than most sold at discount houses today.
Just be/think safe no matter what you use. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Safety is very important. The longer the engine block, the easier it will be for a 3 wheel stand to flip over. I prefer 4 wheels.
Looks like the one in your pic is rated at 750lbs.
I bought this engine stand about 8 years ago for $40 on CL. The only "problem" I have with it is trying to get cherry picker in close. The wide spread of the lower legs make it a little tough for the cherry picker to straddle them. | | | | | Joined: Jun 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 39 | JW51 Depending on how much they are asking for I would snag this one... http://www.harborfreight.com/1000-lb-capacity-engine-stand-69520.htmlI just picked one up and if you aren't already on their text list you get a 20% off coupon. Put it together in about 20 minutes and it is currently holding a promising sbc 350 candidate at the moment.
1955.1 Chevy 5 window 3100 Instagram - @1955.1chevy
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It has been posted many times that the stovebolt engine is a long and relatively heavy engine, you will have to be very careful when rolling an engine around in one of those 750lb or 1000lb stands. I have one that I do not move, and I gave one away. This stand is sturdier and much more stable. It is safe and easy for rolling around and for rotating an engine. I do not remember ever having problems using a shop crane to move a engine onto and off of this stand. If you are careful and if you do not plan to roll the engine much/often, those lighter stands might be OK. Move the engine by pulling from/on the front of the engine and be very careful when turning. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Tim, I like that stand. Affordable too. | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | I had just bought this 2000lb stand last week wanted the sturdy unit to hold my 235. I have a nice NAPA stand that has done well for V8s, but just not in favor of it for a long I6.
Make sure to snag a 20% off coupon and it gets the price down to about $112 (depending on tax). I keep three or four on hand always.
The only thing left to add to it is DEVE's engine plate, making a real sweet rig.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Get the one Tim mentions. Its the one I have and am very very happy with it. Some stands, the engine bobs around while rolling it. This one is rock stable. You get the idea.  Also, look carefully at this pic and notice how much wider I made the wings than the bellhousing. Its important to the design for it to be wider. (the line drawn with sharpie) http://devestechnet.com/Images/Projects/Project1959235/Project59235333lg.jpg | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Looks like someone trusted those engine stands enough to make a rotisserie using 2 of them. Here is the CL advert.
| | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | Someone snagged it before I could. Had the guy talked down to 25 bucks, but it wasn't meant to be.
1951 3100
| | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Why? Also, do you have any pics of after you welded it? | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I am maybe being overcautious Mark, but wider gives those wings a little more stability I would think. I can't imagine a scenario where they would twist, but I would feel better having them a bit wider. Especially if I am the one suggesting the plan! http://devestechnet.com/Images/Projects/Project1959235/Project59235343lg.jpghttp://devestechnet.com/Images/Projects/Project1959235/Project59235347lg.jpgIf its pictures of my welding job you are looking for, I haven't taken any closeups of the weld. I beveled the outside of the tube heavily so I could get lots of weld there, then ground it flat. The inside weld is single pass. I was going to do a double pass, but with a 220 mig on its max setting and the wire speed I used, it all came out really nice the first time. | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Wider IS better! Just wondering if you had a reason beyond the obvious.
Your thoughts on insetting your tube, maybe an 1/8", to make a full weld that you wouldn't have to grind along with your outer fillet weld? This way you would still have 3/8" tube contact on the 1/2" plate with weld on both sides.
Great work! It's always a pleasure to make tools that work better and will last longer than what you could find on a shelf! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I THOUGHT about the idea of offsetting the tubing a bit, as you said. In fact most of the things you see are done that way. But how many people do you know have the patience to use a 3 inch hole saw on 1/2 inch steel? LOL! So, I took the time to bevel the tube which served the same purpose as simply backing it off an 8th. LOL! | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Time and oil!
My last patience exercise was a 5" hole saw along with 2" by 3 holes to make a gauge cluster for the dash. That or fly cutting a motor plate hole.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I use grocery store spray on Canola oil. I couldn't believe it when it was suggested but its perfect for that. I didn't even ruin the hole saw! I am not a fan of the hole saw in general. Wish there were better ways with limited resources to cut a hole. | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I've read some old threads that talk about how topple-prone stovebolt are on a stand. This looks better than those three leg things, but need some advice. Rated for 750 lbs and listed on CL. StandI read through the responses quickly and I don't know for sure if anyone answered your original post! I would use that stand, IF the wheels were not buggered up, and then would use two people to move the engine short distances on level, good quality, smooth cement. When going over the purchase flip the stand to its side and check the wheels, if unoiled or balky, ask the guy for some oil and see if the bearings are shot. If you had to buy good quality wheels that would be $40 or so, might as well go with one of the new ones suggested. If ok in the bearing dept look at all the welds carefully, any re welds, poor welds walk away even if he's selling for a song. I like that lower gusset, could be a higher quality stand. I bought a used heavier duty stand and the mounting area was really buggered up, our own Grigg spent a good hour making it right, btw he's a certified machinist. My lesson is check new OR used carefully.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Jan 2014 Posts: 3,681 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,681 | Thanks, Cosmo. I missed out on that one but good to know that style will work.
1951 3100
| | | | | Joined: Aug 2001 Posts: 3,596 Moderator | | Moderator Joined: Aug 2001 Posts: 3,596 | I made my own engine stand years ago, heavy duty and like Cosmo says, good wheels. Dad built our cherry picker as a three wheel at first, then added a rear stableizer bar latter to make it more stable. Had them both in KC last fall for the motor teardown clinic. We tore down a ford small block, explained what to look for and how to inspect. Alvin could not keep his hands off of it. http://s160.photobucket.com/user/st...005_zps9e3a78bd.jpg.html?sort=6&o=11Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | |
