2 members (JeffA, Mike B),
167
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 9 New Guy | | New Guy Joined: May 2015 Posts: 9 | New to the old vehicle scene. I recently purchased a 1949 June build 3100. Previous owner brought it up from Shreveport, LA., 10 years ago and started a restoration. He tired of the project and bought a restored 1950 and the vehicle that I now have became his parts truck. So I have a basket case. The truck is original, but I think the engine has been replaced. Still a 216 but the identification location on the block is blank and the GM part # is for a 216 in the range of 1950-1953 dark gray blue. The head looks like a build date of March 20 1950 and is green? The truck Vin has build date of June 1949.
I am leaning to keeping it original. To check out the compression on my engine I need an intake rocker arm number #6 from a 216 or early 48-49 235 engine. If anyone has one please let me know.
Regards, Nick
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome Nick, I'm from southern Ont too. You say the truck is original and then say the engine has been replaced. Just a suggestion, get a slightly newer six banger (1954-1962) because they have better oil pressure and will last longer. They should still bolt right in. Have fun with it and don't be shy with questions. Just post in the most appropriate forum. Leo | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Nick, welcome to the Stovebolt. The missing engine number may be because it was a replacement engine??? Oh, and post a Want ad in the Parts Wanted Forum for the rocker arm. There should be many many of them out there. Good luck on your build. We're all here to help you along the journey. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Hi Nick Welcome. Where are you located. I too am retired (well, trying to)in Southern Ontario. My '51 has a '60 engine which I understand was good advice. Peter | | | | | Joined: May 2015 Posts: 9 New Guy | | New Guy Joined: May 2015 Posts: 9 | | | | | | Joined: May 2015 Posts: 9 New Guy | | New Guy Joined: May 2015 Posts: 9 | The missing engine number may be because it was a replacement engine??? When I was researching about the engine, as I was concerned about the no identification number, I came across a statement that replacement block were blank. Since the GM block number was for a 216 after my 1949 June truck build it seems to fit, but I am not positive this is the case. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Nick, if your compression numbers are good, paint it gray and enjoy it. I have a 1964 261. The only way it can be 1964 is if its a replacement block. No numbers on the distributor deck at all! They did some strange things back then. Nobody will ever know your engine isnt original to the truck. If those compression numbers come back poorly, get a 1955-1962 235 or better, a 261 to replace it. A little modification, but nothing earth shattering. Good luck! | | |
