Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (baldeagle, Hanks custodian, Guitplayer, Otto Skorzeny, Maybellene, Hotrod Lincoln, 1 invisible), 43 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
#1104858 05/26/2015 3:53 AM
So I cane across a 261 block numbers 3769717 so that makes it 60 to 62 I believe. The head is 3836848 and that's where I'm puzzled. Isn't that head for a 235 motor?I thought that the 261 head was 3836850please someone School me.
wirewizards #1104861 05/26/2015 4:04 AM
The 848 is a 235 head. Someone already helped you out. Hopefully they drilled the steam holes the 261 block has
wirewizards #1104867 05/26/2015 4:18 AM
Yep, also have an "848" head on my 261. I did have to get the "steam holes" drilled. Machine shop guy charged either $25.
If I remember correctly drill them at 12 degree angle to be sure the holes come out completely in the water passage. I think Deve has some pics on his links.
The 848 is a better compression head as I understand it. And its hard to find some of the others, even 848's, that aren't cracked.
wirewizards #1104872 05/26/2015 4:39 AM
The guy I'm getting it from pulled it from his truck to put a v8 it's a running motor with no problems.
wirewizards #1104914 05/26/2015 3:37 PM
Still might want to magnaflux the 848.
wirewizards #1104915 05/26/2015 3:37 PM
wirewizards #1104916 05/26/2015 3:58 PM
Yeah we thinking the same thing.
wirewizards #1104929 05/26/2015 5:26 PM
I know you aren't close to the Canadian border, but most of the 261s that I see from Canadian Pontiac cars seem to have the 848 head.
wirewizards #1104940 05/26/2015 7:04 PM
The "inventor" of the idea to drill the six steam holes in the 3836848 head and place it on top of a 261 block is none other than General Motors of Canada Limited. Interestingly this engine made the same power with a single carb/exhaust as the Corvette 235.
You Tube
wirewizards #1104948 05/26/2015 7:37 PM
Curt,
Thanks for that information.
Did GM of Can Ltd publish a technical service bulletin regarding using an "848" head?
Was the "848" head standard equipment in some years?
wirewizards #1104967 05/26/2015 9:31 PM
Gas Pumper
Gas Pumper
Since you have a 261, maybe this will help...
http://devestechnet.com/Home/TheVenerable261
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
