| | | Forums66 Topics128,022 Posts1,055,269 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | So I cane across a 261 block numbers 3769717 so that makes it 60 to 62 I believe. The head is 3836848 and that's where I'm puzzled. Isn't that head for a 235 motor?I thought that the 261 head was 3836850please someone School me. | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | The 848 is a 235 head. Someone already helped you out. Hopefully they drilled the steam holes the 261 block has | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Yep, also have an "848" head on my 261. I did have to get the "steam holes" drilled. Machine shop guy charged either $25. If I remember correctly drill them at 12 degree angle to be sure the holes come out completely in the water passage. I think Deve has some pics on his links. The 848 is a better compression head as I understand it. And its hard to find some of the others, even 848's, that aren't cracked. | | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | The guy I'm getting it from pulled it from his truck to put a v8 it's a running motor with no problems. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Still might want to magnaflux the 848. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | Yeah we thinking the same thing. | | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | I know you aren't close to the Canadian border, but most of the 261s that I see from Canadian Pontiac cars seem to have the 848 head. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The "inventor" of the idea to drill the six steam holes in the 3836848 head and place it on top of a 261 block is none other than General Motors of Canada Limited. Interestingly this engine made the same power with a single carb/exhaust as the Corvette 235.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Curt,
Thanks for that information.
Did GM of Can Ltd publish a technical service bulletin regarding using an "848" head?
Was the "848" head standard equipment in some years?
