5 members (dunfire, 2-Ton, jmoore, TUTS 59, WICruiser), 173 guests, and 1 robot.
Topics128,048
Posts1,055,541
Members48,425
#1098011 04/18/2015 2:45 AM
1953 stock 3100. Eight NEW boards, new strips, all bolts in and strip holes line up. The problem is not enough distance between boards. Only 3/8 inch between boards. The strips are riding on top of the boards and are higher than the wood. I think the strips are to wide. Can someone give me a width on these strips?
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
maybe you can trim some off the 2 side boards near the bed sides to get the space you need
if you cant run with the big dogs...then stay on the porch
http://s202.photobucket.com/user/rcplumley/library/
Go to Mar-K's website and you find the correct board sizes.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
The ribs on the strips are supposed to be a bit proud from the board. From mar-k website. The picture shows the wood profile. The groove is where the metal strips set. http://www.mar-k.com/catalog/pdf/instructions/bed_wood_dimensions.pdf
He has provided the information for all to see. Thanks to mar-k for that.
Steve H
I believe the strips should be 1" wide. The boards when installed should be butted together with no gap. The bolt hole would need to be drilled to match the metal strip.
The metal strip should cover the whole recessed area, but set inside the recess.
I just did the bed on my 4t6 recently. Thread here. Mine was a seven board. According to Mar-K their bedstrips are 1 1/2" with a 1/2" gap. I cut my own wood with measurements from another 4t6 here. To maintain a 1/2"gap I had to trim the outside boards a "hair". I think the most helpful information from my experience is to measure the cross members for alignment. Being that it is eight boards wide use your center line and start off the spacing with a 1/4" either side and work out. The two end boards will be smaller than the six according to Mar-K's instructions. Hope this makes some sense. Have fun and good luck
Dan
