| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | 1953 stock 3100. Eight NEW boards, new strips, all bolts in and strip holes line up. The problem is not enough distance between boards. Only 3/8 inch between boards. The strips are riding on top of the boards and are higher than the wood. I think the strips are to wide. Can someone give me a width on these strips?
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Oct 2012 Posts: 57 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 57 | maybe you can trim some off the 2 side boards near the bed sides to get the space you need | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Go to Mar-K's website and you find the correct board sizes. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | The ribs on the strips are supposed to be a bit proud from the board. From mar-k website. The picture shows the wood profile. The groove is where the metal strips set. http://www.mar-k.com/catalog/pdf/instructions/bed_wood_dimensions.pdfHe has provided the information for all to see. Thanks to mar-k for that.
Steve H
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I believe the strips should be 1" wide. The boards when installed should be butted together with no gap. The bolt hole would need to be drilled to match the metal strip. The metal strip should cover the whole recessed area, but set inside the recess. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I just did the bed on my 4t6 recently. Thread here. Mine was a seven board. According to Mar-K their bedstrips are 1 1/2" with a 1/2" gap. I cut my own wood with measurements from another 4t6 here. To maintain a 1/2"gap I had to trim the outside boards a "hair". I think the most helpful information from my experience is to measure the cross members for alignment. Being that it is eight boards wide use your center line and start off the spacing with a 1/4" either side and work out. The two end boards will be smaller than the six according to Mar-K's instructions. Hope this makes some sense. Have fun and good luck Dan | | |
