Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (wvstovebolt), 31 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#1092758 03/21/2015 2:51 PM
I have a 1965 GMC Long bed step side with 4 headlight I have a new wiring harness to install on the headlight is the high beam on the inside or the out side With the high beans on do the low beam stay on also or do they go out
Bob May
The high beam lamps are the inner ones. When on high beam the
brighter filliment in the outer lamp will also light making all four lamps light. The dimer filliment in the outer sealed beam is your low beam.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Riding in the Passing Lane
You will find that the bulbs will not fit correctly in the wrong shell . The noggins are spaced differently.
1972 Chevy c10 Cheyenne Super
Actually the first answer above is incorrect regarding the low beam lamps. The low beam bulbs do have two filaments – the low beam (full power) filament and a low power filament which switches on when the high beam circuit is selected. The low beam filament goes out, and a lower power filament is activated. With the high beam lamps illuminated, the low beam bulbs become marker lamps.
Ron Francis offers a “Headlight Brightener” jumper which keeps the full power low beam filament illuminated when the high beam circuit is selected:
https://www.ronfrancis.com/prodinfo.asp?number=BJ-2
I had enough left over parts to make one of these myself and it works as advertised:
http://imageshack.com/a/img706/1296/jumperharness004.jpg
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
I think Howie is correct. Both lights are on full high beam when the high beams are turned on. The outers have low beams.
Relays are a good idea especialy on the high beam side. The Halegen bulbs draw more current then the older bulbs.
Socket Breaker
Socket Breaker
