Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (1955 1 Series, Otto Skorzeny), 103 guests, and 5 robots.
Topics128,283
Posts1,058,505
Members48,490
ODSS President
ODSS President
Shaken, not stirred... Thirty or so seconds of this method yielded the best flow I've ever had from a rattle can. Translation: user never shook the rattle can long enough or frequently enough.
They do sell a rattle can adaptor for one of these batt. operated Sawzall's but this works just as well and is not dangerous. I used a standard length blade, the longer length would make the task a little easier. Try it, see the difference in your paint flow.
~ Cosmo
1949 Chevy Half Ton
Makes good sense. I might give it a try. Thanks
Thanks....and Cosmo, since its cold weather I sometime let the can lay in the wifes sink with warm water for 4 or 5 minutes. I think it helps in cold weather.
ODSS President
ODSS President
Alvin, good tip!
~ Cosmo
1949 Chevy Half Ton
I like it. Will use that idea for sure. Thanks
Steve H
Cosmo, I tied your saw-saw (hillbilly phraseology) method and I like it, even though I can shake it by hand for 60 seconds faster than digging out the saw and rigging it up.
I always feel ridiculous shaking the can manually, and with the saw-saw method I don't have to listen to the annoying rattle either.
My POS father-law used to work at factory which made metal office furniture and they used rattle cans for touch up. They layed the cans on a conveyer belt on the production line in such a way that they stayed put and spun.
Carl
Cosmo,
I particularly like your container of solvent in the background. I imagine that makes the painting go better, also!
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Cosmo,
Your hand blocked the view of the attachment you were using. Could you re-post a better shot?
Harold
Harold
Harold, it looked like he put a couple radiator clamps around the can, slid the sawsall blade up behind the clamps and then tightened the clams up.
Thanks Alvin. Could not tell if it was a special bracket he used.
HAPPY NEW YEAR!
Harold
Harold
That both hilarious and ingenious.
1951 Chevy Panel Truck
Great video, good stuff.
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
