| | | Forums66 Topics128,274 Posts1,058,430 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Shaken, not stirred... Thirty or so seconds of this method yielded the best flow I've ever had from a rattle can. Translation: user never shook the rattle can long enough or frequently enough. They do sell a rattle can adaptor for one of these batt. operated Sawzall's but this works just as well and is not dangerous. I used a standard length blade, the longer length would make the task a little easier. Try it, see the difference in your paint flow.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2011 Posts: 2,952 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,952 | Makes good sense. I might give it a try. Thanks | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Thanks....and Cosmo, since its cold weather I sometime let the can lay in the wifes sink with warm water for 4 or 5 minutes. I think it helps in cold weather. | | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 |
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | I like it. Will use that idea for sure. Thanks
Steve H
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | Cosmo, I tied your saw-saw (hillbilly phraseology) method and I like it, even though I can shake it by hand for 60 seconds faster than digging out the saw and rigging it up. I always feel ridiculous shaking the can manually, and with the saw-saw method I don't have to listen to the annoying rattle either. My POS father-law used to work at factory which made metal office furniture and they used rattle cans for touch up. They layed the cans on a conveyer belt on the production line in such a way that they stayed put and spun. Carl
| | | | | Joined: Apr 2007 Posts: 1,044 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,044 | Cosmo, I particularly like your container of solvent in the background. I imagine that makes the painting go better, also! Kent | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Cosmo, Your hand blocked the view of the attachment you were using. Could you re-post a better shot? Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Harold, it looked like he put a couple radiator clamps around the can, slid the sawsall blade up behind the clamps and then tightened the clams up. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks Alvin. Could not tell if it was a special bracket he used. HAPPY NEW YEAR! Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | That both hilarious and ingenious.
1951 Chevy Panel Truck
| | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 |
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
