| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | The 54 235 engine in my 49 1/2 ton is still stuck after trying everything. I have found a working 54 235 with transmission. Question, can I unbolt the engine at the motor mounts and universal point and reinstall new or does it require other steps? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are asking if you can install the replacement engine that has a 54 clutch housing attached to it, the answer is "no, not on a 1949 chassis".
You can use your 1949 clutch/housing/assembly (from your old 1954 engine) and whichever u-joint is in better condition.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Beyond the mechanical end of the question is the titling issue. IF your state used the engine number as the VIN on the title, as most did pre '55 and that engine is no longer with the vehicle, there will likely be titling issues arise later if you don't re-title when swapping an engine.
| | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | Thanks guys, won't spend the money for the transmission..
