5 members (52Carl, klhansen, Otto Skorzeny, farmallb, rick46ia), 75 guests, and 13 robots.
Topics128,021
Posts1,055,354
Members48,420
#1063657 10/21/2014 4:07 PM
The 54 235 engine in my 49 1/2 ton is still stuck after trying everything. I have found a working 54 235 with transmission. Question, can I unbolt the engine at the motor mounts and universal point and reinstall new or does it require other steps?
billm #1063664 10/21/2014 4:46 PM
If you are asking if you can install the replacement engine that has a 54 clutch housing attached to it, the answer is "no, not on a 1949 chassis".
You can use your 1949 clutch/housing/assembly (from your old 1954 engine) and whichever u-joint is in better condition.
billm #1063799 10/22/2014 12:04 PM
Ex Hall Monitor
Ex Hall Monitor
Beyond the mechanical end of the question is the titling issue. IF your state used the engine number as the VIN on the title, as most did pre '55 and that engine is no longer with the vehicle, there will likely be titling issues arise later if you don't re-title when swapping an engine.
billm #1064161 10/24/2014 12:31 AM
Thanks guys, won't spend the money for the transmission..
