| | | Forums66 Topics128,010 Posts1,055,305 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 7 New Guy | | New Guy Joined: Apr 2013 Posts: 7 | Tell me more about the rear end swap, whats the rearend out of?
It looks like you kept the original hubs on the rear?
I have a 1955 4400 that I want to swap out the rear end, any help is greatly appreciated.
-mike | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | the rearend is out of a ~2001 Chevy HD3500. the spring pad was a little wider than the original, but not a big deal. The axle is the same diameter as what the original was so the same size Ubolts were used. I did have to cut off the corners of the new axle's spring pad for the Ubolts to clear. The center alignment holes were also about 3/8" off too. So I just ground the hole a little to get them to fit. I used the complete axle and did not switch anything from axle to axle. The hubs are what came on the new truck and have the same bolt pattern and disc brakes. That was very appealing to me with this swap. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Nice job,Fred! Thanks for sharing the info.,on your rear end swap! it'll help several members,I'm sure! Thanks for the update! | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Looking Good! --- Appears to be a Dana 70 or 80 dually. Pretty much the same rear end I put under my '46 Skoolie but with 4.30 gearing and disk brakes. Mine came from a '98 C3500 HD.
| | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | I just looked closer at the step van that I am pulling the front disc brake spindles from and found that the rear axle is also a disc set up. I plan on pulling the front and rear axles before I send it off to the scrap yard. So if any Bolters are interested in the rear axle I'll be listing it in the Classifieds soon. And it is the 10 lug pattern with 19.5" wheels with 8R19.5 tires. | | |
