| | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 16 New Guy | | New Guy Joined: Dec 2009 Posts: 16 | Hey guys on the grill side trim that goes on two sides one lower piece.They have a slight ridge to slide into problem is they won't stay in place any ideas or fixes thanks pierce
peter foster
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I did not have the metal trim pieces but I THINK they just press on and the end sticks under the top chrome piece but not sure about at the bottom.
...I ended up using the chrome looking door edge stuff and just pressing it on my pickup....been looking good that way for years! | | | | | Joined: Feb 2000 Posts: 5,233 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,233 | The lower cross trim piece goes on first, then the sides slide down into the lower piece. The top trim holds the sides in place. Having the top and bottom is the key to keeping the side where they belong. | | | | | Joined: Dec 2009 Posts: 16 New Guy | | New Guy Joined: Dec 2009 Posts: 16 | Thanks joe and alvin. did you see question i had on the door inner channel thanks pierce.
peter foster
| | | | | Joined: Dec 2009 Posts: 16 New Guy | | New Guy Joined: Dec 2009 Posts: 16 | joe or alvin is their a used parts source that you have for parts missing on my 1937 chev 1/2 ton truck thanks pierce
peter foster
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Pierce, the 37 parts are getting harder to find. Just keep bumping an add in the Parts Wanted Forum and maybe someone will see it and can help. I've already given or traded away most of what I had been hoarding! I think Bowtie Bits has used stuff, and you can always check with JimCarter as he has a yard full of stuff from parting out trucks. If its a mechanical part you may want to check with Obsolete Truck parts in Nashville, Ga. They had NOS parts sometimes but you have to call to check. I'll keep my eyes on the parts wanted ads to see what you need. | | |
