2 members (Roxxstar, 1955 1 Series), 298 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
#1029585 05/18/2014 11:24 PM
Hey guys on the grill side trim that goes on two sides one lower piece.They have a slight ridge to slide into problem is they won't stay in place any ideas or fixes thanks pierce
peter foster
I did not have the metal trim pieces but I THINK they just press on and the end sticks under the top chrome piece but not sure about at the bottom.
...I ended up using the chrome looking door edge stuff and just pressing it on my pickup....been looking good that way for years!
The lower cross trim piece goes on first, then the sides slide down into the lower piece. The top trim holds the sides in place. Having the top and bottom is the key to keeping the side where they belong.
Thanks joe and alvin. did you see question i had on the door inner channel thanks pierce.
peter foster
joe or alvin is their a used parts source that you have for parts missing on my 1937 chev 1/2 ton truck thanks pierce
peter foster
Pierce, the 37 parts are getting harder to find. Just keep bumping an add in the Parts Wanted Forum and maybe someone will see it and can help. I've already given or traded away most of what I had been hoarding!
I think Bowtie Bits has used stuff, and you can always check with JimCarter as he has a yard full of stuff from parting out trucks. If its a mechanical part you may want to check with Obsolete Truck parts in Nashville, Ga. They had NOS parts sometimes but you have to call to check.
I'll keep my eyes on the parts wanted ads to see what you need.
