7 members (JW51, Uncles51, Jaison, Wayne67vert, Johnny Rib, Robert Crandall, 1 invisible), 70 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#1028783 05/15/2014 2:54 PM
Just finished installing the rubber windlace in the '53.I belive that is the most frustrating task in restoring the AD cabs there is. This is the 3rd one I have done, and I think it gets more difficult every time.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
31,32,33 #1028794 05/15/2014 3:45 PM
I'll be doing my 53 in a couple days, first need to finish the headliner. Only tip I got on the windlace is: slide down at the gaps in channel top front corner of door, then do back portion and last the part above the door use a screwdriver to tuck that in the channel. Also told to use silicone spray. If you have any more advise I'm all ears.
Jim
1946 1/2-Ton Chevy
31,32,33 #1028806 05/15/2014 4:28 PM
Jim,
I do not use silicone spray - it is a terrible contaminant for future paint jobs (and for paint jobs in the area in which you use the silicone). I use store-brand personal lubricant - it contains no silicone, and no petroleum based compounds, and it washes away because it is water soluble (many soaps and petroleum-based lubricants could degrade the windlace over time).
Another "trick" for moving the new windlace is to cut off a short piece (if a sufficiently long piece was sent to you). Then run that piece through the channel and pry open the channel where it pinches/obstructs the movement of the small piece of windlace.
31,32,33 #1028828 05/15/2014 5:48 PM
Tim, Yes I was concerned about the silicone as well, thanks for caution. Sounds like I need some of that Kentucky Jelly 'KY'! I've gone over the channel once already to pry it open, has several areas that were almost completely flat.
Jim
1946 1/2-Ton Chevy
31,32,33 #1028890 05/15/2014 10:48 PM
I used the dry method
Originally Posted by DADS50
Here is a quote from an older thread
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=677623#Post677623
alans tips
I installed the windlass on my 50 a couple of weeks ago.
I attempted alans method first. But I ended up just laying one edge of the bevel in the channel, then using my favorite busted tip Kline screwdriver worked the other end in the channel.
I took a wire tooth brush and cleaned the channel
Opened up the channel with that old broken tip screw driver .
Then started working it around the channel.
This was the most frustrating project I did on the truck. Cursing included
It took me about an hour to do each door working alone.
I did have to trim the windlass where it comes up against the dash.
completed pic
With some help the slide method may be eaiser. Im just glad it done!
Good Luck
tclederman #1029039 05/16/2014 1:30 PM
I used liquid soap. I did open the channel so a 4 inch piece slid thru easily. I then ran the wiindlace thru the channel over the door until there was a equal amount on each side for the vertical channels. It was still very hard to pull. I don't like silicone for the reasons stated above. I think maybe the problem with the soap is, it dries pretty fast and may make the rubber sticky. Any way I'm glad it is done.
Cleon
1949 Chevy 6400
31,32,33 #1029054 05/16/2014 2:47 PM
I used plastic tool to push the seal into the channel for the most part. At the rear, I was successful in sliding the seal into place. For the front, not so much as once I hit the dash, it became too difficult.
31,32,33 #1029392 05/18/2014 1:36 AM
Gas Pumper
Gas Pumper
Hearing all this, and knowing its ahead of me, I wonder if a person could make a metal tool the size of the channel with a metal handle that could be persuaded into the channel areas that aren't exactly right?
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
31,32,33 #1029418 05/18/2014 3:20 AM
Sure
However, the factory pinches can easily be lifted with a screwdriver.
31,32,33 #1029428 05/18/2014 4:31 AM
What about spreading the channel a bit wider before starting the rubber???
1946 1/2-Ton Chevy
tclederman #1029469 05/18/2014 1:52 PM
A paint can opener works well, also.
Cleon
1949 Chevy 6400
"Another "trick" for moving the new windlace is to cut off a short piece (if a sufficiently long piece was sent to you). Then run that piece through the channel and pry open the channel where it pinches/obstructs the movement of the small piece of windlace."
I tried that with disastrous results at all places where there were curves. The rubber keeps popping out.
31,32,33 #1029626 05/19/2014 2:57 AM
Where I opened up my track a little to much I just pinched it back in. Patience.
31,32,33 #1029769 05/19/2014 7:29 PM
I've asked the Mrs. to pick up some personal lubricant for me to keep in the garage.........
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
31,32,33 #1029779 05/19/2014 8:06 PM
Did she ask "Why?"?
Achipmunk #1029786 05/19/2014 8:30 PM
Patience, smatience. smile I just screwed the popped out sections down with little screws. I am trying to work on that patience thing, I hear that it can be helpful in some instances,
Carl
31,32,33 #1030468 05/22/2014 5:11 PM
Installed passenger side windlace yesterday, all your tips were important, without which job would not have been done. Still it was difficult, had to walk away a few times.
Checked all the channel with small section of new rubber, still found crap in there after several cleanings. (Never got the test piece to go through the top per the curves, which was ok as that area is done with screwdriver). Several spots were damaged and had to address, also filed burrs off a few rough areas until the test piece made it through with no hang ups.
Applied dish washing liquid to channel and windlace, went down back run first then front channel. Last did top section an inch at a time with large flat blade screw driver.
Thanks again fellow Bolters, you're the best!
Jim
1946 1/2-Ton Chevy
31,32,33 #1030496 05/22/2014 9:23 PM
We used to install a rubber fitting around the cockpit of F/A 18's using a highly sophisticated specialty tool: a chowhall spoon. If the two are even remotely related, that specialty tool will help in getting the rubber seated into the channel and won't tear it up as quickly.
Deve #1032196 05/30/2014 4:47 AM
I took a 6 or 8 inch carriage bolt, I think it was 1/4 inch and ground & shaped the head so it was just larger than the windlace channel. Try to keep the edges of the bolt head rounded, not sharp. I used a light hammer and tapped the bolt into the channel and tapped the bolt all the way around the channel to make the channel just large enough to slide the windlace thru. Did not use a lube.
31,32,33 #1032623 06/01/2014 5:27 AM
I got driver's side in a few days ago, section over the door was the worst it didn't like any of my tools. Got it all in except for the back corner over the door, I'm moving on, if it falls out then it's super glue time.
1946 1/2-Ton Chevy
Moderated by  ndkid275, Phak1
